Help
Glenn Hodges
>I coated a bowl with multiple coats of walnut oil that I purchaced in a health food store. The oil on the bowl has gone rancid. How can I remove the oil so I can put on another finish? I would appreciate any help.
Glenn
Help
Glenn Hodges
Glenn
Re: Help
Keith Tompkins
>Hi Glenn, I recently had a similar problem...mineral oil applied in an attempt to mix with the old oil finish was a disaster...dark splotches appeared everywhere. I ended up sanding the whole thing over by hand until no traces of finish were visible.
Re: Help
Jim King
>Boil it.
Walnut Oil....rancid?
Jennifer@Indy.USA
>Glen, I'm not sure...but I think the boiling idea sounds about as good as anything. I'm wondering why it went rancid? I have always heard that Walnut oil doesn't go rancid and that's why it's a perfect choice for kithcen ware and such. I was thinking of trying if for that reason...perhaps I'll save my money?
Jennifer
Re: Help
Bill Neddow
>Any time I have used Walnut oil, it appeared to dry. It is used regularly in France by furniture makers as a finish on furniture -- and believe me, it was dried solid on every piece I saw my neighbour there make over three years. Also, it is not supposed to go rancid. Could the store have sold you something else by mistake?
Re: Walnut Oil....rancid?
Glenn Hodges
>I have used walnut oil before, but this is the first time this has happened. I will not be using it again. I think I will try to sand it, and use tung oil on it.
Glenn
Re: Help
Glenn Hodges
>It is marked as walnut oil, but who knows what is inside a bottle of the stuff you buy. It could not be pure stuff. I know it took a long time for it to cure. I put it aside for about 6 months like I do my other bowls before I sell them. I am glad a customer did not get it. The bowl is about 14 inches in diameter and made from poplar. It will take a lot of hand sanding to get rid of the walnut oil on it. I do not have a container large enough to boil it.
Glenn
Barry Turner
>I just bought some of Mike Mahoney's Walnut Oil at Woodcraft. This is my first experience with using it. It allegedly has been "heated" so that it dries. I used it on a Honduras Mahogany bowl that I finished turning yesterday. I sanded the bowl through 320 grit. The bowl has a very nice sheen and the oil really brought out the figure and color.........but alas........after 24 hours it has not dried. It has a rather pleasant smell, so it's not rancid......yet. The label said to wait 24 hours before applying another coat. How long does this stuff really take to dry? Any comments?
tek-Brunswick, Ohio
>I use Mahoney's on some items. It has never dried in 24 hours for me either. It sometimes takes a week to dry, but it does dry. Lately I've been using General Finishes Danish Oil. I like that better. Sometimes I wetsand with Mahoneys and then finish with Danish Oil.
Stuart Johnson
I'm not a finish expert and don't play one on t.v. but from other threads I understand there are types of Walnut oil. One is for cooking and will go rancid and one is a finish that drys and won't be rancid. I havn't used either.
Re: Help
walt
>My daughter almost died from accidently eating a bite of walnut.Does anyone know if the walnutoil here discussed is actually from walnuts and hence potentially life threatening to
those with nut allergies (walnuts seem to be the most toxic)?
Walt
Re: Help
John Albachten
>Glenn- I use a ton of walnut oil (I buy it 5 gallons at a time) and it can take a week or two to cure. (I coat the bowl liberally then after a while I wipe all the excess off, sometimes I follow with a concoction of walnut oil, bees wax and carnauba wax for a soft sheen)
To cure it must have oxygen to polermize (sp?) or cure. One time I oiled up a bunch of bowls and stacked them together and put them in a box in preparation for a show about 6 months away. When I took them out they were definitely rancid. I tried solvents, soap then boiling and finally got the smell out – now these are my garden and kitchen bowls so all was not lost. This is the only time it happened and now I make sure to keep newly oiled bowls on a shelf where they get plenty of air.
I know there is plenty of controversy about using walnut oil but I like it as a quick and economical finish for bowls destined for use with food. I do let customers know what the finish is but have never had any problems or concerns from customers. -John
