Nova DVR owners:help!
Keith Tompkins
Keith Tompkins
>I turn on a 20" General VS lathe. I am not happy with the outboard unit offered by General, and have been tinkering with my own design. What I have come up with looks remarkably similar to the Nova DVR outboard unit. I'm thinking of purchasing one and adapting it to my General. I can make an adapter plate, that's no problem.
I'm wondering, how well does it perform, and how stable is it under load? Any vibration, etc? I would have to paint it green of course! Thanks in advance, Keith
Re: Nova DVR owners:help!
Gary Ljostad
>Keith have you thought about the Vic Mark unit. I've been using it for about a year on my powermatic and it's rock solid.
Rubberhook
>Is that 3520 on wheels? How does that work for you? It crossed my mind a couple of times, but i talked myself outta the idea. It would be nice to roll it outside on nice days and turn outside, but thought it would be to unstable.
Gary Ljostad
>It is. Being on the tall side, I needed to raise up the lathe (about 3"). Moving it is a bonus. Here is a pic of the final version. Also very stable.
Keith Tompkins
Keith Tompkins
>That appears to be a 24" Powermatic! Nice machine, thanks Gary, I'll check it out....
Gary Ljostad
>3502 with the head slid all the way to the end to turn bigger then 20.
Bill Crommett
>Gary: Could you post another picture so I could see how it is attached to your lathe ?
Bill
Gary Ljostad
>Glad to Bill
Gary Ljostad
Gary Ljostad
georgetroy
>I have the Vicmarc outboard stand. The post holding the tool rest goes all the way to the floor. The stand requires 1 1/4 tool rests, 1" will work, you can shim. The Nova rest fastens to the DVR on the end. It is solid, but not like that Vicmarc. I strongly advise againt an outboard stand like you use on the Delta. They will tilt, I have had it happened, lucky me all I broke was the tool rest and not my head. Listing 2 sources for the stand. GT
http://www.woodturnerscatalog.com/cgi-bin/shopper?preadd=action&key=191-8008
http://www.turnrobust.com/Robust/Vicmarc.htm
Gary Ljostad
>George they must have made changes in the size of the tool rest post it will take. Mine takes 1" posts. I can just take the rest off the lathe and right onto the outboard unit with no shims needed. I agree much more sturdy then the free standing units.
georgetroy
>Yes Gary, you just confirmed what I have been guessing at. Craft Supplies sells the Vicmars with 1" shank tool rests. It stand too reason that the Vicmarc outboard tool rest for them would be the same. I have two Vicmarcs 300 & 175. They both were shipped to US as they make them in Australia. Thereforth all my tool rest are 1 1/4". Robust Lathes in WI sells the machines as made in Australia without any changes. When I was at the KC AAW symposium I ordered a 16" tool rest, 8" tool rest and a vacum plate from Robust. Thanks for the reply back stating what you have. I did get drool marks on the black machines there. GT
GeeSeaWhy
>I have the DVR with the outboard rest and it works well for me but I think you might have problems fitting it to a different lathe. First off, the unit bolts onto the DVR headstock with two hefty bolts. Even if you can find enough iron on your headstock, that's a serious drill & tap job. More importantly, I suspect that the placement of the outboard unit relative to the headstock is fairly critical - get it wrong and you'll find you can't reach anything. I most often use it in the full outboard (180 deg.) position. With a 12" bowl, I usually can't move the toolrest between working the inside and working the outside without first taking the bowl off the lathe or removing the toolrest post. The Vicmarc unit looks like it would be easier to attach and easier to work with.
Graeme
Bill Crommett
>Thanks, Gary !
Good illustration.
