How would you disect this critter?
Jorge Castaneda
>Here is a burl I acquired a few months ago and after looking and looking I still don't know how to reduce it to manageable chunks and as Dominic Greco says, give it the bufalo treatment, in other words, use every bit of it.
It is a 16" diameter ball, weights a ton and has major indentation visible in the picture and another slight one about 90 degrees from this one.
If it was yours how would you tackle it? What sort of things you see coming out of it?
Thanks in advance.
Jorge
Re: How would you disect this critter?
What do you want to turn?
Dominic Greco at home in Richboro, PA
>Jorge,
I went through the same thing last year with a large burl Bill Grumbine gave me. It sat for a couple days until I could think of a way to cut it that would not waste a lot of the wood.
What helped me a lot was first knowing what I intended to turn from it. Since I wanted to turn a couple of natural edge bowls, I chose the area that had a "smooth" curve. This would make a perfect rim for my natural edge bowl. I then cut it up from there. After that, it was a piece of cake to figure out what to make from the rest. Once the initial cut was made everything went much smoother.
As fas as "buffalo-ing" goes, all the large cut offs went into a bin. These were later cut into pen, bottle stopper, clock, and box blanks.
You know, I'm still using bits and pieces of that big burl!
Just think about the kind of bowl or hollow form you want to turn. Sketch out it's shape and map it out onto the burl. You might be able to make the initial cut with a chain saw, then bring it into the shop and use a bandsaw to refine it. I found that using the bandsaw really reduces the waste.
See ya around,
Dominic
Re: What do you want to turn?
Jorge Castaneda
>Hi Dominic,
Whow, that was a fast response. I have a couple bowls and a couple of hollow forms in mind, and of course box blanks and small projects as well, I will look at it with that criteria of a smooth curve and see what ideas will come out for the rest.
Gracias!
Jorge
Mac
>Hi Jorge, If that burl is centered on the trunk as it looks to be,that would make a great hollow form.The two indentations will make great windows into the center.
Jorge Castaneda
>Mac,
That is a thought, it is cenetered, alas! my lathe is not big enough for that aproach,
Thanks for the idea
Jorge
