Cutting #2 M.T. on wood blanks
bill dotten
>I Like John Jordans slick method of making magic wands and want to precut a whole bunch of morse tapers onto wand stock. Other than breaking out that old duplicator. can anybody think of a fast way to cut 50 or so No.2 M.T.s
Dusty
Re: Cutting #2 M.T. on wood blanks
Keith Tompkins
Keith Tompkins
>Hi Bill, another method that would work well is a center designed to accept square stock. There would be no need to form the taper, which would speed up the process. Someone here at WC probably knows a source.
Keith Newton
>I have made long narrow tappers on the shaper or router table with a half round bit, followed with a block plane to turn the football shaped narrow end into a round. It is a lot easier than it sounds. Just make a sled template with about 4" on each end that doesn't get shaped for indexing and chatter control.
Square hole in Morse Taper
Fred in NC
>I have done that! The trick is to start with 4 square sticks, and cut one corner off (at a very slight taper) for about 1" from the end ONLY. When you put the 4 sticks together you will have a square hole. Glue together and turn the whole thing to about 2" dia. Then turn the Morse taper in the solid end.
This works much better when you drill a small centering hole in the tailstock end of the workpieces for the live center.
Norm Smith in Nova Scotia
>Hi Bill,
All that I did was take the blank to the bandsaw and cut a taper on each side going up about 1/2" , put the end into the spindle, bring up the tail stock on the other end and turn your wand. It works and only takes seconds.
Good luck,
Norm
>Bill I just turn the tapers. I mount the blank between centers. Then I measure the morse taper at 2 places usually 1 1/2 apart. I part the wood 1/1/2 apart to these measurments and then cut the taper, usually with the skew but any tool would work. Then I just drive it in headstock and turn. I start with the tailstock in place.
I have the vicmarc 120 and they have a set of jaws that are extended and hold down to 3/8". They are extremely solid. I will turn most things like christmas ornament finials and wands using these jaws with the wood cut square.
For long skinny wands, such as a conductors baton, I start by ripping the wood to 3/8" square (I think, I've forgotten how big the hole in my chuck is) Then I feed it though the headstock and only extend about 3 inches. I turn this to the small diameter of the baton. Then I extend another 3 inches and gradually increase the size. When the end starts to wip I take the point out of my cup center in my Nova live center and bring this up to just sort of surround the point and keep it from wipping. I've turned 12 to 15" long spindles this way that start at 1/4" and go down to 1/8".
>Two or three thoughts. (a lot for me)
When I turn things like this, I have a belt sander upside down in a cradle and I just grind a taper by eye on the stock. Doesn't take much practice until you get good at it and quick.
I have been thinking about some sort of attachment for the belt sander that would allow me to just roll the stock along and grind the correct angle.
I like the tapering jig for the band saw or table saw idea. A little sled that rides in the slot in the table with a fence on it that sets the angle and you could ride the stock through the blade four quick times and have a square taper that would fit your head stock. I think there would be some latitude in the size of the stock and this would still work.
Either of these methods seems faster than mounting the stock on the lathe to turn the taper. That would be mounting it to mount it if you see what I mean.
You can get cutters that are sort of like a giant pencil trimmer. A friend had one made for a custom application for shaping the ends of thousands of spindles. They are available for cutting the ends of chair rungs and other round tenons. Wonder if one of the makers would modify one for the No. Taper?
When I turn stuff like this, I find that if I drive the taper home and the tail stock live center will bear on any part of the end of the stock, that's enough. You are turning this to a thin point in most cases anyway. If necessary, you can "tap" or twist it into alignment.
Mark St. Ledger (I think) demoed at our club. He had a brass "E" made up that he sells. One slot in the E was for the small end of the taper and the other was for the large end. The spine of the E was the length of the taper. You just raked the length and then parted in to the two diameters and connected the dots. Works fine, but still requires mounting the stick to cut the taper.
I like the idea of passing the stock through the head stock. I once turned a nine foot long stick on my lathe that has about two feet between centers for a spindle by passing it through both the head stock and tail stock. You could make a piece of wood that would fit over the quill and drill a hole through it. You could have several that would accommodate any size wand. There are tail centers that have holes through them for a drill bit for drilling lamps. They would work also.
>Barry After you've done it a few times turning the #2 morse taper is just as fast as using the table saw etc. plus you have a round taper that sets in the morse taper more solidly.
It's not as fast as chucking up a square piece in the big jaws of my Vicmarc chuck but it's pretty quick. When I need really good support I turn a tenon between centers that fits in the chuck. The shoulder produced gives more support. I have a center that will fit in my chuck so I just pull it out when done and remount the piece.
I thought about some ways to make this quicker. I think the best would be to make a super-sized pencil sharpener mounted in an hand drill motor with a blade or two set to the right taper. This would be sort of like one of those power tenon cutters I've seen used by people who make rustic furniture from dogwood branches. (Woodcraft #144011, for example, http://www.woodcraft.com/family.aspx?familyid=4427 ) I may try to make one. I haven't looked at a power tenon cutter up close - perhaps it would be easy to modify. One potential problem with turning the cutter instead of the wood would be getting the taper exactly aligned with the axis - something done automatically when turned on a lathe. A fixture in a drill press might work OK.
For now I cut them about 5/8-3/4" long by setting a caliper to just over the widest part at the end of the spindle hole (there is usually a mark on any steel MT used in that spindle). With the blank between centers (I use the 1/2" steb center) I quickly cut to the caliper diameter a little ways from the end with a parting tool, use the same tool to make a short cylinder that diameter, then slightly taper by eye. After I did a few of these it was real easy to get the taper close enough by eye without having to measure in two places. Note the cut can be very rough and sloppy and still work fine. What it cannot be is even a tiny bit too small in diameter. I set the caliper a bit larger than the desired size since if I set it right on I will inevitably make the taper too small with this quick and sloppy method.
This is real quick - it only takes 30 seconds or so to cut one. For the last bunch, I cut the taper on one lathe then tested it in the spindle of a second lathe before going to the next blank.
BTW, as for using the taper - one night I got lazy and tried turning some complete wands between centers instead. I broke three in a row when narrowing the shaft, and this was after turning some great handles! Before that I had broken exactly one out of 50 or so and that was with some very soft and fragile wood. The taper stiffens the entire shaft and helps keep it from flexing as it gets thinner. If it flexes it will throw the wood around and almost guarantee a catch. I used to hold the end with a jawed chuck, but that really gets in the way compared to the taper jam chuck.
The photo is of a blank ready to go. (The bandsaw trimming saves a lot of turning time)
JKJ in East TN
Jennifer@Indy.USA
>John,
If I may ask what are the dimentions of the blanks you start with? My son has just been consumed with the Harry Potter Books lately and I thought I'd try my hand at making a few of these. Perhaps I could devise one that would instantly clean the shop?
Jen
>Now your talking Jen. How about one that will sand bowls as well, oh and one that will set up your tent and put the display racks away when the show is over. I'd also like one that will let my dog out at 4:30 in the morning so I can sleep a little longer.
Re: Cutting #2 M.T. on wood blanks *LINK*
I like to start with 1" square by about 12"-13" or so long. I've made them with 3/4" surfaced stock but the handles end up a little thinner than I prefer, especially if the blank is not exactly centered! However, every single one sold regardless of the dimensions.
If I have shorter pieces, I sometimes make the handle separate and use a contrasting wood for the shaft. I've also made some short wands out of shorter stock, perhaps 7" long or so, especially for little tots.
One caution - unless the wood is quite soft it's easy to split the thined end of the blank as you crank down on the tailstock. To prevent this, I put a small hole the end. The perfect tool for this is the hand-driven gimlet, link below. These are real time savers (and space savers compared to a drill bit chucked in a power drill).
JKJ in East TN
Gimlets
Jennifer@Indy.USA
>John, thanks so much fo the info! The Gimlets look like a handy dandy tool. I just looked at your Wizard Wands post again and have to tell you again how wonderful I think they are. That must have been a really fun time!
Jen :)
bill dotten
>Thanks everyone. I am playing with all suggested solutions. Someone may start to make a big pencil sharpener. In the meanwhile this was a good puzzler and I got a lot of good ideas
Thanks again
Dusty (Bill Dotten)
