ALSO WOOD ID HELP
ALSO WOOD ID HELP
ALSO WOOD ID HELP
Jim King
>Can anyone tell me if this looks like tulipwood ? It was wetted to show the grain better for the photo.
Re: ALSO WOOD ID HELP
Steven Antonucci
I'd say yes.
steve antonucci
Michael Stafford
>Looks like a big ole block of that nasty old tulipwood. You don't want to mess with that stuff. Send it to me and I'll get rid of it for you as well as other nasty old exotic woods you need to get out of your shop.....
Keith Newton
>Jim, That is a nice photo, but I can not tell if the wood being shown is 1" wide or 6" wide. While wetting does make the color pop, it may also hide the fact that the wood was light and soft.
If this is the trivia question for the day, that is fine, but if you really want to know, you should try helping out a little more. Did you cut it from your yard this morning, and is that the freshly cut color, or did you buy it at an exotic wood supplier? how hard and heavy is it?
Here is a link to a photo.
http://www.gilmerwood.com/photo%20html/tulipwood_photo.htm
Jim King
>Keith: The piece is about 4" x 6" x 13" and was cut just out side of town about 15 miles up the Amazon river from Iquitos ,Peru. I wetted it down to try and get a clearer photo but it did darken the piece a lot. It is much lighter in color when dry.
It is hard and heavy, similar to weight and density of purpleheart.
I have looked at dozens of sights and ebay and everyone sells about anything and puts whatever name on it they want. That is why I am looking to see if there is someone who has a good idea before I go thru a pound of paperwork, permits, sanitary certificates etc. etc. plus a few hundred dollars to send the bark, leaves and wood to the USDA tropical lab for verification.
Eduardo Sarmiento Hall-Lima Peru
>Jim the woodturners catalog sells tulip wood check them out
an attempt @ WOOD ID HELP
Keith Newton
>Jim, I am sorry if I sounded short, but I could not tell if you were someone in Chicago who happened to cut down an elm or boxelder in his yard, and had high hopes.
At any rate, I can not be much more help. It has been a while since I have had my hands on any tulip-wood. However, I think that you have a good candidate there. Since it was freshly wetted, and your photo was a little too far out to see the pores like in the photo link that I posted, I was wondering if your wood has open pores comparable to that photo? That photo seems to be a ring-porous as opposed to a diffused porous wood like most tropical stuff that I am used to seeing. Is this at an elevation that has seasons enough to induce a ring porous trait?
I am curious about your photo. In the bottom left corner of your sample, there seems to be sapwood, and inside of that, are several little loops in the dark lines that originate and terminate into a darker line which seems to follow what I would appear to be a normal concentric ring, like an annual ring. This is a trait that I have seen in other rosewoods. It is a trait that I would normally associate with scaring like from lightning or another tree falling and bruising it. Since there is normally any separation of layers, it is more like a bruise.
Do you have personal knowledge of this tree? Or was it near someone's home who would know if it was hit by lightning, or better yet would there have been vines hanging from it that are so full of moisture that they are better conductors which would act as lightning rods that when hit by lightning would explode into steam like 50 long sticks of dynamite that the percussion from the explosion would cause a bruise beneath the bark, which would lead to a darker line from pitch saturation, without blowing a strip of bark off of the tree as it normally does. I believe this would lead to the other lines inside of that doing that other thing which is a little too hard to explain here.
I am not a wood scientist, and am only extrapolating on what little knowledge that I have from harvesting and working with wood for about 40 years now, and being a pretty close observer of nature. so take all of this with a grain of salt.
Re: an attempt @ WOOD ID HELP *LINK*
Jim King
>Keith:
We have a series of woods with this unusual type of grain. I has nothing to do with annual growth rings as we are 300 feet above sea level and about 3 degrees off the Equator, 2500 miles from the ocean. These trees are above flood stage and would not have the growth affected by yearly flooding. This grain pattern appears in woods of this color shown, pinks, burgandies and violet/purple plus some brown ones, orange/yellow and a couple of beautiful black ones that are like macasser ebony.
I cannot explain the grain pattern but it is very nice for turnings. I understand what you say about 40 years and dont know much. I have been at it over 20 and feel as I understand less every day.
For sure this has no connection to falling or bruising. Simply one of those natural things that are not yet explained I guess. I was able to find some nice end grain shots a short time ago on the following site http://www.hobbithouseinc.com/personal/woodpics/tulipwood.htm that seem to make me believe what we have is not tulip wood.
RonZ
>I use a lot of tulip wood and this does not look like it. The darker color grains on tulip wood is signicantly tighter like zebrano/zebra wood.
