Wolverine jig
Wolverine jig
Wolverine jig
W.C. Turner
>Does anybody know why Oneway says, "The rubber feet underneath the grinder should be removed and be re-installed underneath the mounting board if required"?
Re: Wolverine jig
Re: Wolverine jig
DougJ in Crawfordsville, IN
>That way, it will all act as one solid piece, with the cushioning being throughout the whole unit and not just the grinder.
Re: Wolverine jig
Re: Wolverine jig
Bob Persing (Skillman NJ)
>To reinforce what Doug said, the Oneway tool support fixture is mounted solidy to your "base" board. You also want the grindr solidly mounted to the base board so there is NO movement between the grinder (wheels) and the fixture that is holding or guiding the lathe tool being sharpened. To restore the vibration dampening offered by the rubber feet on some grinders, put them under the new "base" board.
HTH
BObP
Re: Wolverine jig
Re: Wolverine jig
Steve Roxberg
>That is correct.
I hope it's not wrong, but mine grinder is mounted to a board, that is screwed down the bench. No rubber gromets anywhere.
Re: Wolverine jig
Mine too !
Fred in NC
Re: Wolverine jig
Re: Wolverine jig
Pete in Holland, MI
>Rubber feet are only to reduce vibration into the surroundings. Mounting the grinder and jigs to a board make them "one machine". That machine, if desired, can have rubber feet to isolate created vibration to the surrounding shop. Without, the bench/cabinet it is mounted to needs to be REALLY heavy, else any sign of out of balance will excite the bench/cabinet and make more noise for the shop.
Re: Wolverine jig
Re: Wolverine jig
Barry Turner
>I've got one of those "Boat Anchor" Delta slow speed grinders that weighs right at 90 lbs. The grinder just sits on the bench on its rubber feet.........not even bolted down. I simply mounted the Wolverine bases to the bench top. Works fine. Grinder doesn't budge.
