200+ woodworking book reviews
Turning tap handles, inserts
Mark Wollschlager
>I was asked by a friend to make a set of 6 tap handles for his bar.
Spindle turning, maybe a bit of off center, 6 kinds of wood.
Cool, I can do this. Practice a bit, not bad.
Oh yeah, I need to set a 3/8" threaded brass insert in the tail end.
I could:
Drill the starter hole while its a cylinder, before details and put the insert in last before finish.
Then I would need to come up with a plug to put the center against while finish turning.
A smaller dowel set in a block, or a threaded rod that fits the insert set in a block.
or
Work up a jig to hold the tap handle in drill press for after turning.
Chance of damaging the surface, not the best choice.
I will work on water and alcohol resistant finish ( epoxy, but not glassy )later.
Any thoughts on a better path to take are welcome.
Thanks,
Mark.
Re: Turning tap handles, inserts
Bob Elliott
>How about using a 3/8" threaded rod mounted in pin jaws of a chuck? Prepare your blank by drilling the required hole and installing the threaded insert. Mount the blank on to the threaded rod and bring up the tailstock for support.
Bill Grumbine (Kutztown PA)
>Hi Mark
I have turned somewhere in the neighborhood of 1000 tap handles in the past 10 years, all for a microbrewery local to me. They are beer bottle shaped and I stain them with a dark brown mahogany to make them look like the typical brown beer bottle. The brewer glues a label and caps each one.
There are a number of different ways for you to get the job done, but I find it easiest to drill the hole in the bottom for the threaded insert before installing the handle on the lathe. I use a large cone center to hold it. If you do not have a lage cone center, you can turn a cone shaped piece to fit over your existing center and use compression to hold everything together.
I also drill a hole in the tops of the same size (makes is easier to stick them on the lathe this way too) and have a purpose built jig that drives the handle with two nails sticking out of the end of the shoulder. If you are turning fancy tops, this step is not really needed, and would just be a lot more work in the end.
I glue the inserts in after turning, dip the handles in stain, and hang them up to dry. Once the stain is dry they are sprayed with water based varnish and packed off to the brewery. Since you are doing just a few, you would not need to set up a production finishing system.
The best inserts I have found are brass knurled threaded inserts from Reid Tool. They are threaded, 3/8" x whatever thread on the inside, and knurled on the outside, so they push right into a 7/16" hole. I put just a drop of polyurethane glue on each one to make sure it holds up under its industrial application. The part number is EZ-218 and they will sell you as many or as few as you want. The number for Reid is 800-253-0421. You can mention my name if you like, but they will have no idea who I am, since I am a very small customer.
If you have any other questions, I would be glad to try and answer them for you. Below is a picture I took several years ago of one of my production runs. He orders 24 at a time so that it is easy to transport them in the case I just emptied from the last order (heh heh heh).
Bill
Mark Wollschlager
>Thank you for the information. I will check out the knurled inserts. I have used the screw in type ( and have some for this project), but they are a real pain to install.
Using a cone center will work for some of the handles. For the off center turnings I would like to use a larger disk held in the insert to allow more variation in the off sets.
Also using a chuckable piece screwed in the end will give me better access to the top for finish turning ( and sanding... its a tool, i've heard ).
Thanks again.
Mark.
Re: Beer bottle tap handles Q:4 Bill G.
Brodie Brickey
>Bill,
Are you using a duplicator when you make those or just a template? They look fantastic by the way.
Brodie
Ric Taylor
1000 Taps in One Microbrewery??? Wow......
Ric Taylor
Brodie and Ric
>Hi guys
Brodie, I am John Henry the steel driving man. ;-) I do these by hand with a story stick and a dedicated caliper - i.e. a piece of 1/8" hardboard with notches cut out - and I can go as fast as a machine. I have three major diameters marked for location and diameter, and the final (fourth) one is the same diameter as a custom turned drive center that fits in my chuck. I can turn one every five minutes, although the last lot I did I turned 13 in an hour. That is full cycle, sanding and everything. I never even bothered to try and set up the Mini Max copy lathe for this job when I had it, since I did not think I could beat that time.
Ric, the beer business has been very good to this guy, which in turn has been good to me. He sends them out to all the bars and restaurants which carry his beer, and as he gets new accounts he needs more handles. I suppose that there is a lifetime to them as well, since they have a paper label on them, but I have only ever had one come back, and that was because I did not turn the top small enough to fit the capping machine. I keep it in the shop for everyone who walks in and wants to know what all those rings are.
Bill
Chris Wright
>Hey Mark,
I also turn quite a few taphandles as there are a good deal of home brewing enthusiasts in So. Cal. I have found the actual bar ferrules (which are threaded as you are looking for on one end) at http://www.taphandles.com. They have a good selection of different ferrules, both chrome and gold plated. The other end is a machine thread, so I use furniture threaded inserts & doble threaded bolts to attach the ferrules.
The inserts and bolts can be found at pretty much any hardware store. I drill the end of the blank, thread the insert in (which has the bolt threads running through it) and then attach the bolt and a spare "turning" ferrule. This end is held by the 60 degree tail center inserted into the end of the ferrule. I then use either my chuck or a spur drive to hold the other end. By using a spare ferrule, I know that end of the taphandle will always be the right size.
Chris
