use of a three-point tool?
GaryG in MD
>I was browsing through the Liberty Tool Company in Liberty, Maine recently (amazing place), and I came across a sort of three-point tool that someone had ground out of an old Nicholson "Black Diamond" "slim taper" #5 file. The price was right.
I have Googled "three point tool" without much success, and I also searched the WC archive, likewise. So it's time to come to the experts: you.
I have read in the commercial ads that this is supposed to be an "easy" tool to use. Some reviews say it's like using a skew. I don't understand that because the angle between the faces is more like a scraper. Most commentaries agree that it makes a nice beading tool and a nice V groover. OK, fine. So how do I really use it.
I would appreciate some comments on just exactly how one approaches the wood with this tool and what applications it has. Does one ride the bevel and roll it in, as with most turning tools? Handle level, low, ...? What is the theory behind this tool? Is it a slicer or a scraper?
I'm ready to use it; I just don't know how or on what. ;-)
...Gary
Re: use of a three-point tool?
Norm Smith in Nova Scotia
>Hi Gary,
I use mine for beading in place of the skew and for v grooving. I find it fast and excellent.
Norm
e
>allan batty makes great use the 3/8th 3-point tool to clean up corners, in threading, for beads, and spindle work. years ago he had us make ours in class from 3/8 round hs bar.
it's used much like a skew and catches just like a skew with improper technique.
Colin Spencer
>Gary
Some people love and some hate them. I am in the love camp, it is s superb tool. As the other comments have stated you can use it for V grooving, great for rolling small beads, use it as a sheer scraper, a conventional scraper or a skew. The trick i have found is to keep it razor sharp. Every time I use mine I touch it up with a diamond file on each face, the key thing is to keep the faces flat and the corners sharp. Persevere with it and I am sure you will get to like it.
Colin
Ruth Niles
>Colin,
Is this a "persevere" like one would need to do with the skew? Is it better than using a skew? I've had one of these tools for years and just never used it, or should say never got in the habit of using it.
Take care,
Ruth
William M. Zerby
>Gary, Ruth,
The only written article on the use of the 3-point tool that I have ever seen came from Bill Jones in the Guild of Master Craftsmen publicaton "Woodturnng". The articles were subsequently published in book form, the title of the one you want is "Bill Jones' Further Notes from the Turning Shop". I tried to upload a scan of the pages, but it failed. If you send me you email address I'll forward them. Or, better, if someone can tell me how to upload a pdf file I'll upload them here. My email address is zerby@nmia.com
Kindest regards,
Bill
Kindest regards,
Bill
Re: use of a three-point tool? vs. round skew?
James McClure
>On a similar note, how does the use of a three point tool compare to that of a round skew. I recently made a round skew out of 1/2" HSS rod and now I prefer it to a conventional skew. I am thinking about grinding the other end of the bar to a three point tool, but wonder if it is worth the effort.
As mentioned about the three point tool, the round skew is not catch proof either though. :-)
RonZ
>I own one and found it easier and more fruitful to persivere with the skew instead. It now has a place in my non-used tools such as my ring tool hollower. I found the investment of Raffan's 2 o'clock hollowing worth the effort to learn. I can hollow out a box faster than I could even find and chuck up a forstner bit.
Colin Spencer
>Ruth, The persevere was if you want to use it as a skew. I use both a 1/2" round and a 1 1/4" oval skew and have little use for a 3/8" skew (using the point tool) as I find I use the large one for most of my skew work. The other uses of the point tool do not need much work to master. As I said in my original post this is a love it or hate it tool. IMHO if you have a piece of 3/8" round HSS it is worth grining the edge and then flatteneing the flats on a belt sander to give it a try. If you don't like it you can always regrid it to another shape.
Colin
John U - Charlotte, NC
>I saw it demo'd by Frank Penta fron the NC Woodturners Guild in Raleigh -- he uses it in combination with a round skew to detail his platters with small beads.
I made both tools after seeing his demo from some round HSS stock -- in 3/8 and 1/4" sizes. By far, I like the smaller sizes better.
To use the three point tool to make v's or beads, hold it with one bevel facing up, and "shove" it in gently to depth. To make the bead, roll it uphill on one side, then uphill on the other. Use the toe point of the skew to refine the bottom line between two beads. Very easy to make small beads -- the toughest part I have is making a series of them the same size!
DWFII
>Does anyone know what the grind angles on the three point tool are?
I have a terrible time with small beads especially in hards woods like black locust using a small round skew. I'm hoping that this tool might help a bit. Heck I might re-grind my quarter inch round skew into a three point...what do I have to loose?
thanks...
DW
In the High Desert of Central Oregon
>For the ones I made, I just "eyeballed" it......somewhere around 45-deg give or take, which leaves a relatively short edge. I'd start short, try it, then lengthen it if needed.
