When to cut a tree
When to cut a tree
When to cut a tree
Barry
>I have an offer of a good sized cherry tree from a co-workers property.
What time of the year is it best to remove the tree, in terms of stable wood that will dry well etc.
thanks
Re: When to cut a tree
George Van in WI
>Barry, I prefer to cut in the winter after the sap is down, up here it's frozen. It seems to help the bark stay on the blank and I dont have problems with staining that I have in warm months.
In the winter
DougJ in Crawfordsville, IN
>after the sap is down.
CapeMayMike
>90% of my cutting has been in northern Pa., 10% in southern NJ. My experience has been that winter cut trees will retain their bark and are more forgiving.....ie: less cracking and checking. I do almost all of my cutting in the winter. The only wood that I've been using that isn't winter cut comes from a nearby tree farm. While the price has been right, bark retention has been bad and I've lost more than the usual number of rough turned blanks to cracking. I need to visit them in the winter!
Re: Depends...
Brian Hahn in SW Wisconsin
>If you want bark-on bowl blanks, then late fall and winter is the best time. (When the tree is dormant.)
If you want bark-off, then spring and summer.
If you don't care, then do it whenever it is convenient for you.
Personally, I'm waiting for the heat and humidity to break so I can cut down a hickory for tool handles. I prefer to strip the bark off before I cut the logs into billets. The bark tends to have dirt (wind-born as well as ground contact from handling) and that dulls the bandsaw blades even faster. Hickory wood dulls them fast enough as it is.
