We value your privacy.
>I need some advice on the best...read easiest...way to remove bark from a burl cap. I have a nice cherry burl that I want to leave the outside shape but want to remove the bark. I then flatten the top and cut a bowl into it and it makes a pretty unique looking artistic bowl. How would I go about this without completely soaking the thing for weeks. The burl is pretty dry for the most part. Would DNA work? Should I just soak it in H2O or maybe boil it??? The last resort is using a chisel and doing the caveman routine, but I fear gouging the wood.
>Power washer does a good job. Not your electric 1200 psi models, mind you, but rather the commercial types or what you get at the DIY car wash. Just remember your safety glasses and don't leave the debris in the stall.
I thought about powerwashing, but I did that once before with some Maple burl and ended up chewing up a bunch of spots trying to get particularly persistant pieces off. Also...it appears that this thing was cut during the sap run because this stuff is on there good....I'm a little afraid to hit it with my 4500 psi unit.
>Bark is easiest to get off in the Spring, but it is not too bad through the Summer, and is hardest in the Winter.
If it has been cut for a while, and has dried out, it will be harder than freshly cut.
If you can get an edge started so you can get some tools behind it to lever it up, you just start prying it out, while you work another tool in beside where the space is just coming apart.
You can use something like a flat pry-bar, but steel tends to turn the sap of many woods black. I have made some spuds out of plastic that I really like. the are about 1" thick and 2" wide and sharpened with about a 25* bevel with a little groove just back from the edge to keep it from slipping out by giving a little bite.
When it is really stuck, you can knock it off with a hammer by striking it at about a 45* back about 3" from an edge.
If you remove more bark than you can turn right away, cherry sap will be badly checked in about 2 days, so you may not want to uncover more than you are going to use pretty quickly.
