Pin Oak odor?
Pin Oak odor?
Pin Oak odor?
Arn
>I recently aquired some green Pin Oak logs from a friend. I know oak is not the best turning wood, but I went for it anyway. I cut them into bowl blanks, coated with Anchorseal and then turned a couple right away. The next weekend I lifted the lid on my shavings barrel and got a most putrid odor that caused me to remove those shavings real quick. I then pulled out some pin oak blanks and they have the same odor, which made it darn hard to get through the turning!
So, Question is: Is this the pin oak or is it mildew or other causing the odor? The blanks are lying on my basement concrete right now, so I suppose they may be getting a fair amount of moisture, but I'm in no hurry for these to dry. Note, I also turned some sycamore that was lying next to the pin oak and it had a similar odor, but not as strong. I suspect the pin oak smell permeated the sycamore.
Re: Pin Oak odor?
Re: Pin Oak odor?
tek-Brunswick, Ohio
>Some oak has a bad odor. People think it smells like old urine. There is a nickname for it. "Piss Oak " I don't think the name is limited to Pin Oak. I've been a carpenter for over 30 years. We put up some Oak Paneling once that smelled so bad we had to tear it out and replace it. That was standard 1/4 plywood paneling with Oak veneer on the front pre-finished and fully dry. I guess the smell can be pretty potent. I burn a lot of Oak in my wood stove. It smells pretty bad when it's green, but usually is all right when it is dry.
Re: Pin Oak odor?
Re: Pin Oak odor?
Mike Schwing from Md.
>Has to be a very special piece of oak for me to deal with the odor. PISS OAK is what we call it around here. I can't stand the stuff. Sometimes it smells like urine, sometimes vomit.
Re: Pin Oak odor?
Re: Pin Oak odor?
Dennis Taylor
>the pin oak is very nasty to smell, I had some pieces stored and thought a animal urinated on it, but it just smells, sometimes I don't think it smells so bad, the next piece is terrible and won't finish it...Dennis
