200+ woodworking book reviews
show me your photo booth
Sascha
>i am ready to improve my pictures and want to set up a nice little photo booth.
i will use halogen lights, nothing fancy, i just want to see if you guys could show me a few setups to model mine after.
which back grounds, fabric for sides and such.
any help or links would be appreciated.
thanx guys
sascha
Re: show me your photo booth
RK in Milw
>Go to Photoflex.com and check out their lighting lessons. They have a product called LitePanel which you can easily make. Make the panel frames from 1" pvc electrical conduit and 1" pvc plumbing elbows. PVC electrical conduit works better than pvc plumbing pipe because it has a thicker wall and is therefore more rigidl.
You can buy the Photoflex translucent fabric from B&H Photo for about $15 or make your own from rip stop nylon fabric. One Playboy photographer used white bed sheets. Either way, don't get your light too close or you might start a fire. Move your light back and forth in relationship to your LitePanel to get a softer or harder lite.
In my photo, the Litepanel is on the left side and a white foamcore reflector is on the right side. I used some plexiglas mirror placed to the right rear to produce some highlites on the finial. There is a spotlite on the background. You could modify a spotlight fixture used for track lighting to create a spotlite.
The background is gray Formica curved up in the back. Another easy way to create a back ground is to paint the back side of some cheap vynyl flooring with flat latex paint. Lots of things can be backgrounds such as wood, ceramic floor tile etc. Look at commercial phtography web sites for ideas. Simple and uncluttered works best so as not to detract from the product.
Hope this helps and be sure to play around and have fun. One note of caution, photography is just as addicting as woodturning.
JamieDonaldson
>Sascha- here is a basic set-up called the "White House" which I have used for teaching the "Phrugal Photo Workshops" for many years. It works for most normal sized turnings and costs less than $40 to build including the Q/H 500W work light fixture. Background is a white vinyl window shade, sides are Foamcore panels fitted to a PVC pipe frame which breaks down for storage, and the light is pointed UP to bounce around the interior.
Photo studio in a box *LINK*
>I got my new Porters catalog this morning and found this. I is a complete studio in a box. 2 lights, light tent, small tripod, and a background. And guess what Jamie, the background is 2 sided, Blue and gray so they can shoot all their wood on the blue background.
The quartz lights are a little weak but since it comes with a tripod you could use the self timer or a cable release to get the very long exposures that it will require. I'm guessing with w 50 watt lights to use f16 you will probably be shooting in the 4 to 20 second range. At 2800 K they are also a tad bit warm for the tungsten setting on a digital camera but on wood this should look OK. The gray background will be just a touch off but that can be corrected in your photo software.
http://porters.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=PCS&Product_Code=45-0675&Product_Count=&Category_Code=
Re: Photo studio in a box
JamieDonaldson
>It's rather small for most turnings,and it still exceeds the Phrugal Photo budget! And notice the blue background is specifically for bluescreen dropouts, not actual image reproduction!!LOL,LOL!!!
