Have a question? Ask Woody!
Templates for cutting true circles from burls
Keith Newton
>I thought I would start a new thread, rather than posting on the end of one a couple of days old.
When I am cutting blanks from burls or any naturally rough topped wood that would be hard to mark on. I have a set of concentric rings that I made from 1/2" MDF with a router on a trammel arm. They all have a few holes around them so they can easily be screwed to the work with a couple of drywall screws.
I find them to be very helpful in visualizing what the top of the turning will look like before I even touch it with the saw, because the inside opening is like looking through a picture frame at the wood you are about to cut.
I try to screw it onto the blank parallel to the axis of rotation, so If I am cutting a piece off of a large piece with the chain-saw, all I have to do is to stay outside of the ring to saw off the rough blank, and then saw parallel to that plane to get the bottom right for the band-saw.
Once it is on the band-saw, I cut just outside of the ring. Once this is done, I have a nice round but cylindrical blank. I then mark a line about 3 to 6" up from the bottom around the outside. I will then tilt the BS table and saw off the waste that falls outside of the faceplate diameter.
Since I have not been to any classes on turning nor taken any magazines, I don't know what others do. Is this a common method that others use? If not, let me know and I will take some photos which will make it easier to follow.
Re: Templates for cutting true circles from burls
Bill Crommett
>What I have done is to make a large number of dics of various diameters out of the Lucite used for the lower portion of storm doors in homes that have rambunctious kids that are prone to bad cuts. These disks are transparent and are tacked to the center of the bulk piece so I can mark a circle with a dense magic marker.
>I use 1/4" luan and made a series of discs. I just tap a nail in and then run them on the badsaw.
woodspinner/ Bill Hale
>Keith
Many of us do it that way but the second step bothers me.
I feel the angle cutting is a step not needed and I think holds to much danger of either blade or FINGER damage. You are going to mount on a lathe that is made to do the job you are doing on the band saw. The outside roughing is so fast and much safer why bother with the saw ?
Good turning and be safe
Bill in Casa Grande, AZ.
John, you need to re-train your...
Clem Wixted
>I use 1/4" luan and made a series of discs. I just tap a nail in and then run them on the "badsaw"
...BADSAW so it becomes a GOODsaw. Badsaw!, badsaw! :-)
I have a sticky keyboard also :-(
Clem
Ron in Drums PA
>I use corragated cardboard.
Re: John, you need to re-train your...
>Clem Your right. I sold my Taiwanese BAdsaw and got a Delto Goodsaw with riser.
Carole in VA
>Why do you saw off the waste that falls outside the faceplate diameter? Why not just turn it off? Am I missing something?
Ron in Drums PA
>It's easier.
Besides, many times the cut offs can be turned into something.
Keith Newton
>I do it that way because it is just faster, and easier, and I don't think that it is that dangerous.
I have a 36" badsaw, with a 7.5 HP motor, and about 20" to the right of the blade, I don't think I can turn that same volume of wood into shavings as fast as that thin blade can slice through the wood.
I suspect we are thinking of different scale. If I were doing a small piece, I would not bother, but the larger the work, the easier I think it is to saw it off.
