Vacuum Chuck Question *LINK*
Jim Shaver - Oakville, Ontario
>Hi,
I have been thinking about making a vacuum chuck that would work on my Jet Mini or my General 160-1.
Recently I bought a VacuPress Compact 100 veneering system. I was wondering if any of you might know or be able to give advice on the vacumm pump from this system, would it work in a lathe vacuum chuck application?
take care,
Jim
VacuPress, Compact 100
Re: Vacuum Chuck Question *LINK*
Eddie Pacheco; San Jose, Ca.
>Jim,
I have this vacuum press, but changed pumps. This pump would be marginal and would need an accumalator tank in order to deal with any leaks or partial leaks that occur while holding a bowl on your vacuum chuck. A rotary vane pump that flows more air would be a safer bet.
Bill Crommett
>Jim: The variables in the vacuum chucking situation are: The integrity of the system,the porosity of the wood, the delicatness of the cut by the operator, and the intensity of the catches expected. From this aet of parameters, almost any small pump could work, but with most of us we need a good bit of overkill to compenste for the weaknesses in the system.
Re: Vacuum Pump
Ed Thomas, Leaside (Toronto) Ontario
>That pump will draw a good enough vacuum, but you'd be short on CFM.
A member of the CWW forum was looking for a pump a couple of years ago and I sent him off to a Used Graphic Equipment dealer in Scarborough. What with all the print shops going Computer to Plate (no film) there is a glut of used vacuum frames out there. I just sold a 3000W unit for $100 complete with pump and kept a 1/6 HP Gast vane pump from the other plate burner for myself. It's loanable at the moment.
Steve Roxberg
>There is a supply of Gast pumps 220v for $89 dollars that would work a whole lot better. The Surplus Center is selling them and they work great, but since someone will ask, these cannot be rewired and must run on 22O.
Specs.
1/4 HP Rotary Compressor Vacuum Pump
• New GAST 0523. Direct drive, oil-less, rotary vane vacuum pump. Motor is thermally protected and will restart automatically after the coils cool.
SPECIFICATIONS
• HP 1/4
• Voltage 220 AC
• Amps 1.5
• RPM 1725
• 4.5 CFM at 0 PSI
• 3.6 CFM at 10 PSI cont.
• PSI 15 int.
• 0.5 CFM at 26" Hg max.
• Ports 1/4" NPT
• Duty continuous
• Thermal protection on motor
• Size 5 5/8" x 13 1/4" x 6"
• Shpg. 31 lbs.
Gast Pump at Surplus Center
CapeMayMike
>I bought one of those. If you don't want to run 220 you can use a transformer that they sell to go 110. See the link.
Transformer for pump
Pump 4 sale
Bernie
>I have a Robinair model 15600 6cfm unit 110v with a on/off switch
sold many on this forum and to my local club.
175.00 shipped to your door.
Bernie
Re: Pump 4 sale
vicmarc.fan
>Is this a pump you use oil with?
Ron
