Gopher wood supplier source?
Keith Newton
>Ugh. I just Googled the subject line, hoping to find some unusual wood, but all I found was the same joke / sermon about 1000 times. I followed that with olive wood, and or woods from the Holy Land, and all that turned up was novelty stuff.
I have been ask or commission by a church to turn a re-usable cremation vessel, for the funeral service, which will conceal a stainless steel vessel which contains the ashes that are then interred in the columbairum, as the service comes to a close.
They thought it might be nice to use a wood with religous signifigance. The SS container is 6" dia. X 8" T, and will need some finger room around it for lifting the inner vessel out, so I will need a blank that is about a cubic foot to start with.
If I can find a fine piece of wood with strong charcter, I would probably keep my part of this equation simpler than if the wood is plain, which would require that my part would need to be more sculptural in nature to achieve the effect that aspire to.
Does anyone have a source that they could link me to if something special comes to mind? So far I have only used local woods that I have found or that has found me, so I am not up on buying wood of this nature.
Thanks in advance for your help. Keith
Re: Gopher wood supplier source?
Carol Reed, the Router Lady, Dubuque
>Consider myrtle wood. It also has Biblical significance, but finding something that size will be a challenge. Large enough pieces of olive wood are available from Arizona (where I am from). Contact Sean Troy at the Arizona Woodturners. He posts here and he ought to able to connect you with a source. Since Arizona and the Holy Land share similiar flora and fauna, you may be able to find what you'd like there. And don't forget to check with Woodfinder.
I made ecclesiastical furniture for years and I understand the desire to use a wood with a Biblical connection. In fact, I used to give a talk about Biblical woods. For the size you have in mind, olive will be your best choice. I'd also look for dogwood but I am not familiar with the size of available pieces.
If you want to have a little fun and an educational exercise at the same time, just Google a wood species and 'Bible' or 'Biblical' forcing both terms in the results and see what turns up.
Re: Gopher wood supplier source? *LINK*
Tim Grenville-Cleave
>Any good?
Tim
http://www.bethlehemolivewood.net/
Keith Newton
>Thanks Tim, I had found that one, everything there was just too small.
I guess I may have to find a tree that a gopher once tunneled under, and make it about 1 cubit long to send them off in. Har. K
Jerry Whitaker
>You might just have to gopher any wood if you can't find what you are looking for.
Bill Crommett
>Kieth: In order to decrease the size of the bulk block, consider a change in your design to allow a little of the stainless steel container to rise above the opening for a grip. Then structure a lid that would fit over the whole assembly concealing the steel container. Just a suggestion.
bill dotten
>come clean! you are building an ark but you won't warn us of the coming flood
Dusty
Dog
>The Torreya Tree is the source for Gopher Wood. The only two locations that it grows in the U.S. are Florida and California. Torreya State Park is located in Liberty County, Florida. Perhaps they can suggest a supply. The Trees I have seen in this park are on the small size, but perhaps the Ranger can point out a tree of size that blew down in last years Huricanes. The wood is very similar to Juniper or cedar, perhaps it can be turned with success.
