Veritas - Innovation in Tools
Turning Brass Fittings
Stuart Johnson
>What tools are you using to turn brass and copper fittings?
Re: Turning Brass Fittings
>I use files, followed by 600 grit SiC (cloth backed emery paper works well, too, and a buffing wheel, same wheel I use for honing carving tool edges.
Brian Hahn in SW Wisconsin
>Standard turning tools work fine.
Steel is so much harder than brass (or copper or bronze or aluminum) that it's not much worse than turning wood. And high speed steels were originally developed for machining metal.
Just keep the lathe speed way, way down.
Ken Grunke from SW WI
>A pyramid point tool works very well, as does a skewchigouge which has a flat top which wouldn't tend to grab like a gouge might especially on copper.
For hand turning, metal is best scraped instead of sliced as we like to do with wood.
I have a few tool handles made from 3/4" round steel and setscrews at the end to take square HSS machinist toolbits, which are cheap and easy to grind to various shapes.
eaglesc
>Any tools I have laying around that is high speed steel.
I have some sheet maetal tools that haad seen better days so I ground then down for profiles I needed.
I did origianlly use my reglar HF turning tools and they worked fine but decided to use something I wouln't mind sharpening more often.
My diamond stone puts an edge on anything quickly.
I use them on casing( bullet) pens all the time.
Thanks
Stuart Johnson
>Thanks for the information. I thought I was going to have to invest in another set of tool.
Bullet Pens?
Eddie Pacheco; San Jose, Ca.
>Hi, do you have a picture or a link where I may see these? I haven't heard of these before. Is the shell casing the back part of the pen and the turned wooden portion, with the mechanism, is a "slug" that fits into the shell?
Thanks.
