Shop Heat
Shop Heat
Shop Heat
Guy
>I know, old subject but I keep hearing conflicting reports. Looking into upgrading my heat for the shop this year. My wife is spending more and more time in there so the propane space heater has to go. The shop is 14 by 24, insulated with a slab floor. We are going to put in "snap tile" floor like in garages. What I would like to know from those who use them is how much does it cost to run radiant electric heaters or propane heaters like the Hot Dawg by Modine? We are definitely more tempted to go with electricity because our propane proces have almost doubled since last year. We are in the shop every weekend for 12 hours or so and a few nights a week. We are located in Kentucky so it definitely gets cold enough for heat. Don't really plan on heating the place 24 hours a day but only as needed. Any hints, info, places to buy also would be greatly appreciated.
Re: Shop Heat
Re: Shop Heat
W.C. Turner
>Where at in Ky.?
remove nospam for email
Re: Shop Heat
Re: Shop Heat
Donna Banfield
>Have you considered installing a pellet stove? They don't require a huge set-back, like a woodstove does, meaning you won't give up a lot of your shop space. Even the least expensive has a blower that will throw the heat, and the installation of one is easy compared to a woodstove, or radiant floor heating, if you don't already have the lines laid in the flooring.
My husband and I installed ours in a couple of hours. No permit was necessary in our town (Derry, NH), so don't know about KY.
Re: Shop Heat
Re: Shop Heat (Long)
Tim Grenville-Cleave
>I don't know much about your Building Regs (Codes I think you call them) nor your energy prices ... but here in the UK it is an accepted fact that it is easier (and cheaper) to heat areas continually then up the temp slightly just before use. My choice of heating, (subject to the area to be heated having resonable insulation in place), would be individual thermostacticly controlled wallmounted radiators. Easy to control the heat output, no scource of ignition and you could always put a shelf above the rad to collect dust and other useful stuff!! (No major increase/decrease in temp /humidity, also slight increase in drying times for wood and finishes etc)
My shed (read 'shop') is 50' away from the house but given the quality of plastic 'pushfit' pipework and fittings also the insulation available, such an extention to my heating system is planned for this year. If I DIY then total costs will be no more than £200 / US$350 (ish)
Just my £0.02p
Tim GC
Re: Shop Heat
Re: Shop Heat
Les Robison
>My shop is aboout 16x35 and is insulated. It gets about 30 degrees in the winter and stays that way most of the day due to fog. I installed a 30 amp breaker and use a Dayton 220V electric heater. It is thermasticly controled and is very small. It will run me out of the shop in 1/2 hr. I only paid about $170 for it including shipping. I ordered it from Arrons Creek and it is a Dalton heater. Les
