We value your privacy.
>Well this was a week of learning and I am a long way from the end. I was able to produce two beautiful funnels this week. One was a learning bowl and the other was a gift for my Brother and future Sister in Law. Unfortunately now my wife is headed to the department store tomorrow to buy something. I am now sitting down with a beer too discouraged to try anymore tonight but this will definately not keep me from trying again.
Lessons Learned (in no particular order)
- know how deep your bowl goes
- there is such a thing as too thin
- don't wait till three nights before to make something
I did not mind learning these lessons on one of my many learning bowls but the gift hurt because I had spent a lot of money on the wood and there party is tomorrow.
I have some questions maybe some of you might help me with;
1. My tool was becoming very hot when I was using it on the wood. Is this from a dull tool, a bad sharpening job or pushing the tool the wrong way?
2. I would often get checks or tears in the wood, would this be caused from the same things?
As a side discussion, other than a chip catcher for your vacuum what have some of you done with your funnels you have made? Not that you ever have.
>We ALL make funnels and other blunders, even experienced folks! Check the one below...
My goofs usually go in the fireplace, unless Mrs. Schwing-a-ling rescues them. Damn her!
Don't give up! Couple of answers for you - 1. Cutting tools get darned hot when working with dry wood, so do chips and shavings. Sometimes even not fully dry wood will make tools darned hot, and the steam can burn you, too. Dull tools usually won't even cut the wood, but can cause burn marks, and if you're pushing into the cut with a dull tool you may be bruising the fibers, too. This will all contribute to heat build up.
To help keep from going through the bottom, you can drill a hole down the center of the interior to mark the depth. Hold the drill bit up to the bowl rim on the exterior to gauge the depth desired, mark it, and drill to that depth. Then, when you turn the interior, and you find the end of that hole you drilled, you're done!
Checks in the wood usually occur from wood that is not fully dry - hot tools and worklights dry it out quickly when fresh wood is exposed and it shrinks rapidly - and checks. Tear out is common for all turners and most woods, but as we progress we learn how to minimize and even eliminate most of it. More important to learn basic tool control, IMO, than worry about tear out at first.
Keep at it. After a few hundred bowls you'll be able to do these things with your eyes closed.
>Being not very far from your status as a beginner myself, I offer the following suggestions:
Ever wonder why so many wood shops have a wood stove? Get a wood stove for your shop. Then you won't have to ask people what-to-do-with-mistakes.
Tools can get hot, especially if they are not used properly. Bowl gouges and scrapers can get hot any way when used on dry wood.
Make a depth guage for bowls. The easiest is to use your bowl gouge and your thumb. Until you gain more experience turning bowls, you might want to stick with bowls that have thicker walls. They're more forgiving.
If all of this advice doesn't help, you can always go for more beer.
"Keep at it. After a few hundred bowls you'll be able to do these things with your eyes closed."
It took me about 200 bowls to get to the skill level where I didn't have to worry so much about techique and could start focusing on form. Boy, I produced some ugly bowls when I was first learning!
I've seen this advise over and over again, and it's good. Find a source of "free" wood and fill the trash can with shavings. And fill it again, and again, and again. Think of it as batting practice. The object is to develop your skill, not hit a home run.
(Easy for me to say now, but I also remember back when I was learning to turn that every bowl and piece of wood was precious to me too.)
>Ditto to all of Mikes comments! Another thing to look for is making the transition from the sidewall to the bottom of the bowl. When you go from the side to the bottom you have to swing the tool handle around faster. I made a few funnels from not swinging the tool handle fast enough. What do you do with a funnel? Well if its Buckeye Burl, you use it for the skin around a dragon’s eye. I kept this buckeye burl funnel on the shelf until I found that use for it. The wood was just too pretty to throw in the fire.
>Spend some time watching an experienced turner or get a few lessons.
Any help you get now will speed your learning curve and will direct you in a direction of good not bad habits. Ask for help on this web, give your address and I think some one will offer.
>Find out if there is a turners club near where you live. Belonging to one here in Montana did more to help me than anything else. You can go the the American Asssoc of woodturners site on the web to find the closest one.
>I've know what you are talking about Derek, we have all been there.
I'd suggest a lesson or two if you can find a good teacher near you. Also there are a few good dvds that can help. Our Bill Grumbine has an excellant dvd that will take you through all the paces.
>Good advice above Derek. I had one break loose today and it made me as mad as the first one. There will be more for me unfortunately, my response will be the same!
>Every piece is a practice piece for the next piece.
You have to blow up a few to learn what the limits are. As you get better, you will be able to push the limits back a bit. When i blow one up, I tend to grieve. Especially if I was deep into tit and really liking the work so far. So, I blow one up and quit for a while, until I shake off the feeling. My son, when he blows one up, says "got to get some more wood," and moves on.
I love turning green wood. A very different experience and if you just look around you can get more than you can turn, free. Well, the wood is free, but then there is the truck to haul it in and the chainsaw to cut it up with and the band saw to prep the blanks on and more, but the wood is free. Practice on cheap or free wood.
Join a turning club and hook up with guys that are already collecting wood. Don't want to buy a chainsaw? Trade some labor for a few blanks.
Some mentioned drilling a hole in the blank to set the depth. Good idea. I sometimes set my tail stock at the end of the bed and retract the quill to a "known position". Then I figure out how deep I want the bowl to be. I measure the distance from the known position. I was using a chuck to hold the blank and I knew that if I cut to with in a half inch of the chuck jaws, I could put a nice bottom on the bowl. I actually a have a stick (a piece of dowel)that is a half inch short of the distance from the chuck to the tail stock. As I hog out the interior of the bowl, I use my stick to check to see how close I am to the right thickness. Sort of a depth Gage.
Most people measure the depth of the bowl from the rim. You can put a straight edge across the bowl and use a rule to check the depth. This requires you know how deep you want it and that you leave the rim alone. Lets say you have a four inch deep blank and decide you want the interior to be three inches and that will leave you a bottom that is an inch thick. Thats enough to cut off the screw holes or chuck foot and still have a half inch bottom. If you forget and cut a 1/4 off the rim, and still make it 3 inches deep, you could end up with the bottom thin by a 1/4. I would rather not reference off the rim, because it keeps changing.
Another thing I do is figure out where I want the bottom of the bowl to be. I use a square and mark the position of the bottom on the bed of the lathe. Then I set the square on the bed and measure into the bowl. I actually put a piece of masking tape on the side of the bed and make my marks on that. IF the square is vertical, I can see how deep I am VS how deep I want to be.
Get a set of calipers to tell how thick the side walls are. Your fingers will lie to you. I have a homemade set I would not trade for the world.
Turn with a face shield, not beer goggles. You can also wear a glove on your left hand. I have a leather one with the fingers cut out. Does a world of good keeping hot shavings at bay. And yes the tools do get hot in dry wood, especially if you are rubbing the bevels.
I only have access to dry wood for turning and yes the tools and the wood get hot, some times the heat builds up and I have to pull the tool away because the heat from the shavings is too much for my hands. I turn some woods to shape slowly taking light cuts, with some other woods I vary that process. I sharpen often to keep the best cutting edge and the most economical cut possible.
Sometimes I get tear out if I go too long between trips to the grinder. I have also started to hone the edge some times to optimize the edge for as long as possible.
Hope that helps with the rest of the great advice the others have given you.
>I'm near the same spot you're in. I have spent the last month working on a black walnut bowl that was to be my best ever piece. I spent a lot of hours making sure every step was done correctly. I had dyed the edge with India ink and just finished rub on poly. All that remained was to turn off the tenon. Oops. Won't fit in the donut chuck I made. So I make a jam chuck and use cork on each end to keep my finish perfect.
One little touch up spot to go and it flies off of the lathe and hits the wall and floor spinning.
Scratched and a small gouge. But I was so twisted I threw it and added a couple deep cracks to the scratches. Damn near had me ready to give up but I grabbed a roughed sassafras bowl and started on it and so far its looking good. The next step is to turn off the tenon. BTDT !
I suggest you quickly make something. The success will raise your spirit.
>Thank you everybody for all your positive feed back and tips. You have no idea how good it feels to read your responses of encouragement and knowledge. I plan to get back at it tomorrow with a few pieces of free wood and do some more basic practising.
Thanks again and give yourselves a pat on the back for me.
