We value your privacy.
>Getting better. Made a phrugal photo booth, one 500w qh lite on the left and a smaller one right with a foil bounce card on right. Tungsten setting on white balance. Still seems dark on the right. Maybe a larger bounce card or ??
>David I'm not sure what your booth looks like but you definitely need more light on the right. You may not need another light on the right side just pick up more light on you bounce card. You can do this several ways. One is to use a more reflective card. Cover a piece of carboard with Aluminum foil. Try krinkled aluminum foil first. Another way to do it is to aim your light in front of the wood instead of directly at the wood. This is called feathering the light. This lessens the light that hits the wood and the hot spot from the center of the light will be aimed right at the reflector so the reflector can bounce more light back in.
In my studio I use diffusion panels. I can put a diffusion panel in front of the light between in and the subject. This softens the light and makes it spread more. then if necessary I can let the light "spill " past the diffusion panel and hit the reflector directly. This "hard" light that hits the reflector is sometimes too bright and I have to go back to a white board instead of almuminum foil.
I can e-mail a copy of my photo booth which is different than Jamie's Frugal booth. They both work we just approach it differently and you may find one better than the other for your work.
I may be out of touch for a few days. I have a late photo shoot tonight starting in just a few minutes and then I leave for Nashville for the Tennessee Woodturning symposium in the morning.
>Dave, I think part of it is your backdrop being too close and giving an illusion of less light on the piece's right side. Granted, there is a lack of light on the piece itself, but the darker backdrop accentuates it. If the backdrop were further back, and wasn't directly illuminated, it would have a nice gradiation from dark at the top to almost white towards the front.
>Dave- making the light uniform usually requires a large light box or tent, and I suspect this plate is near the size limits of your set-up. To balance light equally you need 2 equal output sources, but that makes a rather uninteresting photo lacking depth. John and Ken have given good help, so try try again!
>Thanks, guys, good ideas. I'm leaving for a "vacation", driving from CO to Wisconsin with wife and two boys. Wish me luck! I'll try again when I get back. Again, thanks.
