We value your privacy.
>I would love to have a bandsaw with a rotating table for cutting blanks, not an add on but a real bandsaw designed for turners. One with a means to clamp a blank to a rotating table and easily and safely saw it round. I know it wouldn't be cheap but that wouldn't matter because it would save me a lot of time. Is there a "machine" in your mind that doesn't exist, "yet"?
>I saw a bandsaw with a sliding arm with a pin sticking up. This arm could be adjusted a certain distance from the blade and locked down. Your blank was then centered over the pin and rotated to make the cut.
You could probably make a jig to fit over the table on your band saw to do the same. Good luck OB
>I think you guys are hoping for something that sounds great, but is likely to perform a bit less than wonderful. Band-saws with rotating tables have existed for a long time, and may work fine for thin homogenous materials, but for thick irregular turning blanks, I don't think you would get the same results.
The problem that I see, is that once you start through a thick blank, you will find that the blade likes to find the path of least resistance, and will start to wander off. Once this happens, the only way to get it back over to where you would like for it to cut, you must guide the work by over-steering back in that direction. If you are locked into a fixed center, there goes your ability to guide the work back over, and the blade will just keep wandering more and more off until it bogs the motor down, or the blade will break.
What sort of method are you using now? maybe there is something that you should try differently.
While your dreaming we might as well do this with water jet. You would place the wood on the table and the wood would never move. The water jet would trace the profile you want. This way you could cut up really uneven burls.
I had to photograph a big robot CNC mill the other day. You could program the entire bowl into this and it would cut it. It's robotic arm would reach up and change it's own bits. It's an amazing machine. It only cost a Quarter Million but at the prices you get for your bowls that shouldn't take long to pay off.
>CNC just costs a lot more than a regular machine.
Of course, a CNC wood lathe would need a motorized and controllable carriage similar to a metal lathe. This makes a metal lathe the best candidate for conversion to CNC.
CNC spindle turning is rather easy, bowls are a different six-pack of root beer .....
>OK, how about a hydraulically dampened arm with a rotating head at a fixed height, and another pivot point at the connection to the bandsaw down low that would allow horizontal movement only. You could lift a 500 pound piece of wood on the table and then be able to control the cut with a minimal amount of effort and cut it just like you would on a regular saw. With control of 2 axis, and the height always constant, it just might work. Does this make sense? I would think it could be built relatively inexpensively.
>This robot could carve anything you could put into the computer. When we were there it had just carved a really convoluted truck bumper 7 feet long. It looked like it had been stamped. All the curves were perfect. It is truely amazing. Carving a bowl would be a piece of cake. Now carving a hollow vessel might be tougher.
>If you remember earlier in the year I mentioned enrroling in the CNC courses at the local college. I have finished both the CNC lathe and CNC mill courses ("A" on both, hehe!). The new semester starts next week, and I am taking other machining courses. I am also taking full 3D CAD drafting, which of course, is necessary to produce files for the CNC.
CNC bowls ? Who knows! My main interest is in making TOOLS !
Have you seen the RotoZip and similar? They have a bit that cuts sideways. The same kind of bit can be purchased for metal mills as a 'fast roughing' bit. All we are interested in is taking off the excess material and leaving a circle.
Grizzly (and others) offer machines that could be adapted by adding the rotary table.
>This isn't totally different from by friends bandsaw mill. The log is mounted between centers, you rotate it and cut off one side, then rotate it and cut off another side. If you turned this system on it's side the log could be rotated through the bandsaw blade.
>I have a piece of half inch melamine coated particle board with a stick on the bottome that slides in the slot on the band saw. There are two rows of holes in it (odd and even) and they are drilled so that when one side of the board is flush with the leadign edge of the table ODD is in line with the blade. The EVEN row lines up when the other edge is flush with the back edge fo the table. I put a pin in a hole that corespondes with the size of the blank I want and Drill a hole in the blank at the cneter and set it on the pin on the baord, Turn the saw on, slide it into position, cutting the entry for the blade and then rotate the blank. Works well. If I have a blade on the saw that does not "like" cuttign circles, I just shove the blank past the saw, rotate and slice again and again until I have a eight or sixteen sided blank. I often use the same hole for the woodworm screw.
The problem with the lazy susan would be that you can't cut a blank smaller than the lazy susan.
I do like the over arm Idea. I might put an attachment on my homeade low tech one jsut to control the "tip" of the blank.
