Side grind jig
W.C. Turner
>Does anybody use the Packard Woodworks Side Grinding Jig(Item # 148801) to replicate the Ellsworth grind?
Thanks,
W.C.
Side grind jig
W.C. Turner
Thanks,
W.C.
Re: Side grind jig
Gary in Zirconia, NC
>Yes, I have heard it is identical. I like mine.
Re: Side grind jig
William M. Zerby
>W.C,
I teach sharpening techniques at the local woodworking clubs, woodturning club and the local Woodcraft store. I use my Wolverine vari-grind jig to grind the relieved finger-nail grind ala Ellsworth.
Here is the recipe. Set the pocket arm distance to wheel tangent = 6 1/2" - 6 5/8". Use the fourth notch aligned to the top of the angle arm (approximately 40deg) . Use 2" gouge stick out from the business end of the jig. Adjust the pocket arm distance until you get the grind angle at the nose to be what you want. I think David recommends 65deg.
Here is the recipe for the standard spindle gouge finger-nail grind. Set the pocket distance to 5 5/8" - 5 7/8". Use the second notch aligned tothe top of the angle arm (approximateyly 25deg). Use 1 3/4" gouge stick out from the business end of the jig. Adjust the pocket distance to get the grind angle at the nose to be what you want. Typically I use 30 -35deg.
There is some variation from setup to setup because the height of the grinding wheel center changes from grinder to grinder when the Wolverine is installed. Typically you want the grinding wheel center height to be no higher than 6 1/2" as recommended by Oneway as I recall. This is why the pocket arm distance is a range rather than a specific value. There are other combinations that will get similar results. Start with these and play around until you find a combination of angle, pocket distance and gouge stickout distance that gives you the grind you like.
Kindest regards,
William M. Zerby
