Razertip Question
Razertip Question
Razertip Question
CapeMayMike
>My wife has been using her new razertip, decorating her gourd art and also boxes and platters that I've turned. She's also using it to do the bottoms; specie, date, signature, etc. This task seems to be taking longer than anticipated, her feeling is that it may be due to the tip that she's using, a standard that's included with the tool.
For those of you using the Razertip on the bottom of your work to sign, etc., which tip are you employing?
Thanks,
Mike in hot and humid Cape May NJ
Re: Razertip Question
Rick Allen
>Hi Mike
Razertip has two tips that I like for signing. One is the extra small writting tip. This is a very small tip that lets you write a fine line. Produces a line about the size produced by a fine tiped Sharpie. This is the 9XS tip pen.
The other tip I tend to use more often is the smallest ball tip. This makes a slightly larger line The size of a regular Sharpie. But the big advantage of the ball tip is that the pen doesn't catch on the grain like the extra fine writing tip does.
The third signature was written with the tip of an extra small skew. It is very graby when writing and take a LOT longer to write with.
Good Luck
Richard
CapeMayMike
>Thanks Rick! That's the info we were looking for.
Mike
john Lucas
>Mike I use the skew for all straight and curve lines. These go faster and cleaner than the writing tip. I used the writing tip for small curves, dots and writing. The temperature you use and the wood or in your case gourd material also affects how fast you can go. On a smooth even grain wood I can turn the heat up a little and draw quite rapidly. On wood that has heavy grain I have to work with the heat down and go slow over the winter wood.
CapeMayMike
>Thank you John.
Chipster
>We were just in Provo a couple of weeks ago, and Treeline has an extra, extra small ball point tip. It is not in the catalogue, but if you call, PJ will be more than helpful in getting you what you need. It does a great job!
