Plywood Bowl
Plywood Bowl
Plywood Bowl
Stuart Johnson
>I've been trying to work on my form and decided to save my better wood. This bowl is Birch plywood with a Mahogany top ring and Walnut bottom. The plywood was a plesant surprise. I didn't find it too bad other than needing to sharpen more often. Frequent sharpening is probably a good habit anyway. I am about to give up on plain Mahogany rings. The end grain sucks up the glue and leave a dark line no matter what I try. Any suggestions? There are some chatter marks where the Mahogany and plywood meet that I didn't see or get out. All in all I like the results and will work on the next one as if I want to keep it. Unfortunately my wife wants this one warts and all. It is 10" x 3". All comments or critiques are welcomed.
Re: Plywood Bowl
Re: Plywood Bowl
>Stewart Very pretty. Try using the endgrain to your advantage. Cut the pieces so you have either all end grain or all side grain and then alternate each one. this may mean you have to increase the number of sides otherwise you get end and side grain in the same piece when you turn it. Another option is to turn the endgrain up. You'll have to orient the pieces differently when you cut the miters. With the enggrain up you would have nothing but face grain on the sides then the top would get darker from the finish and might look very interesting.
