dead center
Mike Schwing from Md.
>David, not sure if that was tongue in cheek or not, but dead center chucking these things are a snap. Here's one way
Determine center by drawing the standard X from diagonal corners. Mark it on the side that will become the top of the bowl/plate.
Chuck up a glue block and turn it just barely concave, maybe 1/64th depression center/edge. This will prevent wobble and provide good glue surface at the same time. (some turners will disagree with this and insist it has to be dead flat - whatever works is fine by me) Apply glue of choice (mine is 5 minute epoxy)
Lock the headstock. Bring the tailstock in close. Take the workpiece and put the tailstock center point in the center point you marked on the workpiece earlier. Crank the tailstock to move the workpiece into the glue block. Before it gets tight, but when it is seated, give the workpiece a 1/2 rotation spin by hand, this will ensure it is seated well on the glue block. Crank the tailstock to firm up the glue joint and wait for it to dry. If done correctly it will be damned near impossible to center it better.
(I think you know this next part but it might be new info for others) If your tailstock live center is threaded, you can buy or make a tailstock chuck adapter that will allow you to screw the whole chuck and workpiece onto the tailstock, which can then be used to perfectly center the work on a jamb chuck or vac chuck so that the bottom can be turned and finished. Works great!
