200+ woodworking book reviews
Do you wax?
Do you wax?
Do you wax?
Bill Howatt
>I use the Beall system with tripoli, white diamond and carnuba wax as provided. My typical finish is Lee Valley's Polymerized Tung oil which is usually gloss but I have sometimes cut the gloss with some of their sealer.
I am wondering just what the wax is providing me since PTO is very durable and has plenty of shine. I have had some comments from people I have given bowls to that after a while the finish isn't as nice as it originally was and I have re-buffed the wax to correct it. Nothing serious just a little shopworn from being handled. I don't think I am putting too much on.
Is the wax really worth putting on? I must admit it sure makes the bowl feel nice.
Thanks,
Bill
Re: Do you wax?
Just a guess Bill
tdaniel
>Are you sanding to a fine grit before applying the tung oil finish? Tell us more about your application method and we'll be able to give a more accurate answer.
TD
Re: Do you wax?
Re: Do you wax?
Bob Way, Canton, MI
>I've heard they all hurt, but that the bikini is the worse.
I just had to get that in before someone beat me to the punch.
As for the Beall, I've kind of been convinced that my finish has provided the bulk of the protection for the wood, but that the wax gives it a depth, and that feel you mentioned, that adds a little something extra to the look and feel of the piece.
Re: Do you wax?
Renaissance Wax *LINK*
David Propst
>When I took a class with David Ellsworth I remember him saying Carnuba will absorb water with aging and dull. Still, nothing finishes off a turning like wax. I buff with tripoli and sometimes white diamond, then buff with Renaissance Wax, which is a microcrystalline wax with very good results. So far, so good. Most WW Shops carry it. Click the link below for more info.
David
Renaissance Wax
Re: Do you wax?
Re: Do you wax?
Bill Stehman
>My father turned 1000's of pieces over his life and loved waxes for that finishing touch. Waxes dull over time and soften which dust clings to. I am slowly restoring some of his work and have learned never to wax athough I too liked the extra shine when I first started turning.
Re: Do you wax?
Re: Do you wax?
David Hammond, in Powder Springs GA
>As far as I know, wax is supposed to be a final finishing touch, and it is not just a finish that is applied once - and wax is a finishing touch that has to reapplied over the years - hence my hesitation to go to a hard, buffing wax, rather than a soft furniture wax. But I'm not sure, I just know that most of the older waxes were never meant to be applied once, and never reapplied; these hard buffing waxes are relatively new, and I guess I'm not sure what you do long term with them...
I use Goddard's Furniture wax, which is very soft with a slight lemon scent - it doesn't give you the increase in gloss that most of the buffing waxes do, but it does give you a nice soft, satin feel.
David
Re: Do you wax?
Re: Just a guess Bill
Bill Howatt
>I sand to 400 always and often to 600 or finer. I apply 1 coat of PTO sealer and then 3 or more coats of PTO. I am always careful to ensure the coats are "wiped off" after a few minutes so they are thin and smooth.
After waiting a minimum of 24-48 hrs (I prefer to wait longer if I can for better curing) I buff with tripoli and white diamond and then apply the carnuba wax. Sometimes the tripoli step is skipped.
Bill
Re: Do you wax?
2 things to try
tdaniel
>First, try getting some oil into the piece before sanding to a fine grit. I normally start putting oil in while sanding with 100 grit and continue wet sanding with each grit. You must use a slow drying oil to do this but after you are finished sanding you can switch to a faster drying oil/varnish.
Second, give it more time to cure before buffing; just because a finish feels dry it is not hard so give it a week or 2 before buffing.
Let us know if this helps.
TD
Re: Do you wax?
I'm looking into the laser hair removal, myself.
Gary Evans Tallassee, TN
Re: Do you wax?
I'm using the natural hair removal process, age
