Veritas - Innovation in Tools
Supernova 2 question
Carole in VA
>The chuck has an indexed backing plate to supposedly allow users who do not have a lathe with indexing capability to index. Neither the manual which came with it, the CD or the website explains how to use this feature. In fact, the manual and CD are for the Supernova not the Supernova 2. I don't have a clue how one uses this since I have never used indexing. Can anyone explain?
Re: Supernova 2 question
ben d
>Carole
Go to ther web site and there is customer service there, e-mail them and they will reply. I have had several questions answered in this manner.
http://www.teknatool.com/
Also
Jorge Castaneda
>While in the Teknatool site, download the current manual for the Supernova2.
To use an index, all you need is a reference, you can call a hole 0 or 1 and take it from there, maybe mark it with nail polish or something, and somewhere in the head of the lathe in a part that does not move you put your reference, a mark or a hole.
Hope this helps
Jorge
Carole in VA
>Already done that. Hope to hear from them in at least the next day or so. I just want to know how it works. Looks to me like you would have to have some sort of fixed reference pin to go in the holes and a means of locking the spindle? I have been googling to see what I could find and when I came across a small pic of the Sorby Indexer that's what it looked like you had to do. If I could just see indexing in use, I am sure I would probably think "Oh...OK! Duh!"
Re: Also
Carole in VA
>I had already done that this afternoon when I realized that the included manual was for the Supernova, but the new manual didn't mention anything about the indexing either, other than the fact that it was a "feature". Must be so simple that they figure only an idiot wouldn't know how to use it.
I have that chuck
Fred in NC
>I looked at the back of the chuck, and found the holes too. They are very small, in a plastic part, and two holes are missing.
My solution was to start from scratch. I worked with a machinist friend of mine, and we used his lathe and mill to make the plate. I used a precision rotary table to drill 24 holes. The pin that fits in the holes is slightly tapered to assure a tight fit.
The pic shows the indexing plate being held by a nut. It can be used with any chuck also, you just use the chuck instead of the nut.
Re: I have that chuck
Fred in NC
>The pic shows the "low banjo" I made to go with the indexing plate. It can hold a table or any other custom made tool holder. This is what is holding the table in the previous pic. It is 1/2" thick steel. This thing is rigid !
Dremel holder
Fred in NC
Ah hah!
Carole in VA
>That's how I thought it should work, but never having seen it I wasn't sure. I would just need the banjo with an indexing pin that fit in the holes in the back of the chuck. A pic is worth a thousand words. Thanks.
