Newbie question - skew chisel
Robert Henderson
>What is the diference, functionally, between a standard skew chisel and an oval skew chisel?
Re: Newbie question - skew chisel
>Functionally very little if any. I've heard there is less vibration from a standard skew but I haven't been able to tell the difference. I can tell that there is less vibration from my big 2 1/2" skew but then it's 3/8" thick where my oval skew is about 1/4" at the thickest part. The only difference I can tell is in what I'll call a paring cut. This is when you use the skew kind of like a large parting tool or a tenon cutter. The oval skew will rock on you and can get a catch if your not careful.
Ed in No.VA
>Oval is harder to sharpen as you have to keep the thing from rocking.
RonZ
>IMHO its best to start with a standard skew. Much more stable, less catches, and easy to sharpen. Preferably with the edges slightly rounded so they won't catch on the tool rest. Once you are comfortable with the skew and you're looking for more fancier moves with a skew, then add an oval to your collection. Nick cook recommends a larger one for stability.
