WOOD HARDENERS
Jim King
>Does anyone have a link to a site explaining the use of wood hardeners on soft woods ?¿
WOOD HARDENERS
Jim King
Re: WOOD HARDENERS *LINK*
Keith Newton
>Is this what you are after? http://www.abatron.com/home002.htm
Re: WOOD HARDENERS
Ric Taylor
>Keith,
Do you use this material? Does the liquid dry clear or colored? Any experiences or info you can share?
Thanks,
Ric
Re: WOOD HARDENERS
Keith Newton
>I have used a couple of the thin epoxies, although I am not sure that it was this one. I was thinking that it was by -----Smith? but this was what I found bookmarked.
Here is another source that I have used. The price is better here.
the thin stuff is clear, and does not set as hard as normal epoxy, but hard enough to make a lot of difference I am not sure this is the same stuff that they use for knife blanks commonly referred to as stabilized wood.
Now both of these will soak great into decayed wood, but may not go far into a sound but naturally soft wood. They also normally have a slow cure time to allow for deeper penetration
I Think You Forgot to Mention the Other Source
Ric Taylor
White Glue
David Propst
>Before you invest in wood hardeners I would suggest trying soaking the wood in 1:1 white glue and water (about $10/gal). Wally Dickerman suggested this technique and it has worked wonderfully for me on spalted poplar with some really soft areas.
I rough turned the pieces and soaked for a couple of days and then let dry as normal. Tearout was eliminated. A pleasant unexpected benefit was the glue soaked wood absorbed an oil finish very evenly between endgrain and sidegrain. On a piece I had not glue soaked, but finished the same way, the endgrain came out dark and muddy.
David
