Beating the Jet Mini to death!
Mike in Fort Walton Beach, FL
>All the Jet Mini talk over the last few days has me interested in some things. It seems that I am going to go with a Jet Mini and it will be my primary lathe for a long time to come (I move at Uncle Sam's whim and have a weight limit on my household goods when they send me elsewhere), so I am going with the non-VS version because I will probably use it to it's capacity and don't want a power drop which seems to come with the VS. However all the other talk about reversing the VS has me wondering, can I reverse the regular mini by the same method? I think my friends are as excited as I am that I finally get to buy my lathe so I can quit using theirs :-). Thanks in advance for the info.
Re: Beating the Jet Mini to death!
Bruce Wiseman
>Hi,
To my very limited knowledge there is no way to reverse a single phase AC motor. The Jet comes with a sigle phase AC motor so no. But that being said I am sure someone out there has some ingenious way of doing it.
Regards,
Bruce
William M. Zerby
>Bruce,
Actually there is a type of single-phase induction motor that has a reversable rotation. Its is the "split-phase induction motor". They come in a number of different flavors. The last one I had was a Fractional Hp Dayton motor (1/2 Hp as I recall) that I purchased from Grainger. There were several wires that you could bring out of the case that allow reversing by shutting the motor off and then switching the order of the main winding and the auxiliary winding which then produces the desired effect of shaft rotation reversal.
Kindest regards,
William M. Zerby
>I had a Craftsman single tube lathe when I was about 16. My first stationary tool. A friend showed me how to attach onto the two reversing leads or wires in the box on the motor and run them out into a single gang box and hook them to an ordinary two slot outlet. The other end of the two wires were hooked to a cord with a two prong plug, like a short extension cord. When you wanted the lathe to run in reverse, you unplugged the cord, twisted it to reverse which prong went into which slot and plugged it back in. It was an ordinary 3/4 Hp motor that I bought at Sears with the lathe. Now I realize you can do the same thing with a DPDT switch, but when you are 16, this looked like genius. It worked for almost forty years until I sold the lathe and may still be working. So, Yes, there are single phase motors that can be reversed.
john Lucas
>Mike Personally I wouldn't worry about reversing. I've turned for 20 years and only recently have a lathe that will reverse. I don't see the advantage. I've tried sanding in reverse and I end up with the same quality piece in the end. Therefore why take the chance of the chuck coming loose and losing the work. Since I don't have chucks that lock on the lathe the danger seems to me to be much more of a hazard. Maybe some woods will sand better in reverse but I haven't found any.
Brian Hahn in SW Wisconsin
>If the motor is a capacitor start induction motor, it is reversible, but it might not be easy or convenient to do.
I use the reversing feature a lot when I'm sanding. It's not a problem with spindle work, but for faceplate work you have to be careful not to unscrew the chuck. I spin my chucks on really tight and only use light pressure while sanding, so I normally don't have a problem. I have turned in reverse on between centers work where the grain or angle was a problem, working from the back side of the lathe. But that really is a case of I did it because I could, not because I had to.
>Just a hint for those who turn spindles. You can sand in reverse by simply fliping the spindle end for end. When I first saw this demonstrated it was one of the DUH why didn't I think of that reactions. Hopefully someone else will find that useful.
One word...err Acronym
Jay in TX
>Mike,
Being in a similar professional situation (spent a couple years in Fort Walton myself!), I'd suggest DITY. I had similar reservations about purchasing big iron, and came to the conclusion that I could put in a little sweat equity for move in CONUS. OCONUS is a little different, but as much as 800 lbs is (approx weight of the PM 3520a I think), you can make it up in other places. Remember, as the years pass and promotions come, HHG weight allowances increase. The mini will do well for you, but I'd take the Russ Fairfield advice for the beginner... buy the "other white machine" or your equivalent dream machine.
On a side note, my allowance coming here to Texas was exceeded by 3 tons (6000 lbs)! Your favorite Uncle (mine too) only had to ship 5 tons (well below my threshold) and I DITY'd the other 3.25 tons. Your Uncle was satisfied, and I made enough to pay for my rental and fuel costs. Hey, who'd uh thunk these Texans had trees! So I brought my own. ;~)
Your brother-in-arms,
Jay Kilpatrick... on the lookout for a "BIG" chunk of mesquite to test the mustard monster; got any?!?!
Turning in reverse
>>I wouldn't worry about reversing...
I use the reverse a lot on my lathe but I agree that it's not a necessity. All my chucks and face plates are locking (I had to modify one myself) so since it's easy to reverse I alternate directions while sanding spindles. This is also sometimes handy while power sanding the inside of a bowl.
There is one other thing I have found very useful at times: I sometimes turn the inside of the bowl with the lathe in reverse. This lets me cut on the opposite side where it is easier to see without leaning. It does take a bit of practice to turn on the back side since the motions are different.
JKJ in East TN
>Thank you everyone for the inputs. Sanding was the primary reason for wanting the reverse action. I saw a video by an older gentleman (can't remember the name) who swore by reverse sanding. I think I will be doing primarily spindle work so swapping it's orientation might be the best option anyway :-). I like the idea of wand turning (made one out of mahogany) and am looking forward to the corncob pens in the next issue of Woodturning Design. So... anyone in the Florida Panhandle have some off cuts of wood that they want to unload cheap?
Thanks again for the advice,
Mike in Fort Walton Beach, FL.
