We value your privacy.
>Quite some time back I acquired a Sorby mega bowl gouge, its probably 3/4". I put a fingernail grind on it like I have on my 3/8ths gouge. I can turn the outsides of bowls fine with it, the insides are another matter, all the gouge wants to do is hop around, seems like I cant get it to bite and make a continous cut and chip.
Should I be using some other type of grind on it other than the fingernail grind?
>Rick, without watching what you are doing, I am just guessing, but when you are on the outside, you are probably only using a small portion of that thumbnail, because most of the outside is curving away opposite to the grind. However when you are on the inside, the sweep of the inside curve matches the curve of the cutter causing it to cut with the whole length of the blade.
If this is the case, and there is any flex in your faceplate, tool-rest, or tool, there is likely to be some resonance setting in somewhere causing your problem. I personally don't like a blade width over about 3/8" for inside work, and I have a mega-lathe.
You can get a lot of flex out of the wood as the walls get thin also.
