Turning Gum tree wood
Phil in NJ
>I got a whole tree worth of gum wood that was being cut down across the street.
I haven't ever turned gum before.
The first piece I cut appeared to have some spalting as well as rather strange discolorations. It also was a bit punky I think. Some of the other logs are more uniform in color, while some have a lot of staining on the ends of the logs.
Does anyone have positive or otherwise experiences turning gum?
I'm just learning, so if I've picked up a bunch of wood that will be a poor learning wood then I'd love to know that before I get frustrated...
Re: Turning Gum tree wood
Darryl Hansen
>Sounds just like some "gum" my friend gave me. Has blck and brown streaks throughout the blank. Stabilize the punhy stuff with CA. Finishes nice. Seems to be rather dense but sands easily and looks very nice. The wavy lines makef for some interesting turnings. Difinately keep it.
Dick Hines
Dick Hines
>Turn it green and soak the pieces in alcohol. I have turned a fare amount of gum and every tree seems to be just a lttle bit different.
It is instering too se the look on peoples faces when they find out the nice bowl or hollow form is made of that damned old gu tree. Yep the one with all the sticky balls.
Kudzu
>If it is green, wear a rain coat. Put up a shower curtain behind the lathe because it is going to sling water everywhere!!
Wood come out really light, almost white. I really like Gum. Took the limbs and turned ornaments out of them too
