Got Wood?
Got Wood?
Got Wood?
>I'm a novice at wood turning and am wondering why I can't use some of the scraps left over from my flat work? I seem to recall that kiln dried lumber doesn't work well for turning. Is that true and if so, do you know why? Thanks.
Re: Got Wood?
Re: Got Wood?
>Works quite nicely. Segemented works can be made from scraps (if you have the patience to do the cutting and glue-ups). That's on my list of round tuits. I have turned knobs and buttons for larger pieces out of scraps. You can match woods or do a contrasting one for "drama".
Re: Got Wood?
Re: Got Wood?
>Thanks, JL. I produce a lot of hickory, cherry, oak, etc. scraps that I've been giving away for firewood to a neighbor. I can't use my lathe yet or else I would have tried turning some of it. Looks like I can glue some up and use it for practice.
Re: Got Wood?
Dick Hines
Re: Got Wood?
Dick Hines
>kiln dried wood is not as much fun to turn as wet because you don't get all those nice curles. Other than that it turnes just fine. If it is not thick enough to get a bowl glue up enough pieces to do the job.
I save the small pieces for pens ad collers on hollow forms and finials on things.
Re: Got Wood?
Re: Got Wood?
>Cherry and walnut are used more than oak and hickory for turning. (KD hickory can be especially difficult to turn)
Green wood is fun to turn. But one big advantage of using dry stock is it will be dimensionally stable and less likely to end up being oval instead of round.
I often use 4/4 or 5/4 stock to turn small objects such as finger tops and thin spindles. I've glued up some to make bigger things like bowls. A friend of mine made some great lamps by gluing up 6/4 squares.
Some people glue up contrasting woods. When turned, the boundaries can create some very interesting curves.
One thing about turning dry wood aggressively, such as when turning the outside of a bowl - the tools can get hot! The shavings can be hot. For more fun and less pain I use several gouges with the same grind and switch to a cool one as necessary. Some people use a glove on one hand to protect from hot shavings. Heat is usually not a problem when spindle turning.
JKJ in East TN
Re: Got Wood?
Re: Got Wood?
>Frank The vast majority of things I turn are from dry wood. I make handmirrors, boxes,inside-out turning, wine stoppers, christmas ornaments and turned shelves. I could make the wine stoppers out of green wood but you risk checks in those. I do make some Christmas ornaments out of green wood but most are dry. I don't make many segmentted vessels anymore but used to make a lot. Malcolm Tibbits has just released a book on segmented turning that is the best one available. If you want to try some of that I would buy that book.
Re: Got Wood?
Re: Got Wood?
Brodie Brickey
>Frank,
Don't forget platters. You can make plates from 8/4 stock.
Brodie
Re: Got Wood?
Re: Got Wood?
Bob R
>Frank
I agree with John. I only turned dry wood scraps when I started turning and people say they are great and they bought them. I am now trying to learn green or wet wood, its all different turning and finishing.
They are both great types of turning.
Bob R
WestMac Turning
PS Dry wood is more time consuming..
