We value your privacy.
>Here's a witch whose design was borrowed from one of the AAW Symposium pics that had been recently posted. It was made from a piece of red oak that I had lying around the shop. To turn it black, I burned it with a propane torch, and then applied a bit of black stain after it had cooled. It worked pretty well, although some of the thinner sections developed cracks as a result of the burning. Overall size is 4" diameter by 14" high.
>I'm using Woodburst stains and I've found from past use that the stain does blacken the wood as evenly as I was after. After staining, some areas of the wood will be totally colored/black, whereas other areas will be lightly colored and show some of the original wood color.
Burning the wood seemed to darken it quite well, although some areas were still a bit light. Applying black stain after burning produced an almost "ebonizing" effect - I learned this mainly as an experiment that went well in this case. The end result was total darkening of the wood, and I found that burning the wood with a torch seemed to penetrate quite well (the color didn't disappear even after light sanding).
If you try this, my only word of caution (aside from "don't burn down your shop!") is that you should use care when burning thin sections, as the burning caused some cracking in these areas for me.
