Re: Will only work if.....
RK in Milw
>I do sand the inside of my hollow vessels. I came up with my own device and you can either make one yourself or purchase one from me for $25. I call it the ACME Sand-o-Matic.
I use this sander on a Sorby Multi-tip tool, or even better, on a Sorby Hollowmaster ( the swan necked tool). The sander can be rotated to fit the approximate contour of the vessel interior as needed. The sander also works well for sanding undercut bowls.
1. The dense rubber foam is from a sanding block that comes in a Micromesh kit.
2. Use the teardrop shaped scraper blade from the Sorby Multi-tip tool as a template and trace it on the foam using a ball point pen. Be sure to trace the hole for the mounting screw.
3. Cut the outside shape out of the foam block using a band saw, jig saw or whatever. The sides need to be perpendicular to the face and as smooth as possible.
4. Coat the shaped foam block with thin superglue. This provides a smooth surface for the self adhesive velcro hook material.
5. Using a brad point drill, drill a 1/2inch hole where you marked the screw hole. This is the hole for the nylon bushing.
6.The bushing is 1/2inch o.d. x 3/16inch i.d.x 1inch long. I sanded mine to a length that matches the thickness of the foam - 7/8 or 3/4 inch long.
7. Rough up the outside of the nylon bushing and superglue it into the 1/2 inch hole in the foam shape.
8. Apply a trimmed length of self adhesive velcro hook material to the outside perimeter of your sander.
A 2 inch dia. velcro backed sanding disc cut in half works well as an inexpensive sanding media.
There you have it. Hope this helps. Feedback appreciated.
