We value your privacy.
Thought I'd share a neat thing I saw one of the students at Arrowmont using to burn rings around a bowl. He was using one of those sample squares of Formica counter top, the ones that hang on the sample board at Home Depot and Lowes. He held it in the previously cut groove on the rim of the spinning bowl to make the burn. It was so fast and so easy! Burned a clean black line almost instantly. Much easier and safer than a guitar string or other type of wire.
>I tried that recently on a tool handle that I was making. The handle was hickory, about 1 3/4" in diameter. The Formica "melted" and the hickory only got a slight tan. I switched back to stainless steel wire and nearly set off the smoke detector.
The Formica is great for places where you can't use a wire though.
>Jennifer Hardboard works well also if you need a thicker line. By best friend uses cardboard to burn larger areas. You can get it to go from brown to black using the carboard. It also works great when you've textured a surface to burn the top suface and leave the texture clear. You do have to spin the turning rally fast for this.
>Jennifer, I have been using those sample chips for 2-3 years. I very seldom use wire anymore. When you are through burning the ring you don't have to worry where to put the HOT wire.
