Holly Question
Holly Question
Holly Question
>This morning, my neighbor two doors down had a live holly tree. By noon, most of it cad been eaten by the chipper, but I rescued four sections of the trunk, about 13" dia. x 18" long. I know there are problems with fungus staining of holly. What do I need to do to have the best chance of keeping it white? I know I have to act quickly.
Some of it I hope will be turned into bowls. some will be spindle turned, and there will be other things I can also use it for. I guess this is a minor gloat, but I think about the lost potential in the rest, and in a couple of other trees, that went into the chipper, because I don't feel like I have the resources and energy to save all of it that might be useful, especially with the current oppressive heat and humidity. There's still quite a bit of hard maple, some spalted, that I can go get if I want it.
Re: Holly Question
Re: Holly Question
>I recently got some green holly from Gary Evans. I bandsawed it into a variety of blanks, anchor sealed the ends, and stacked loosely with lots of air space. Haven't seen any fungus or staining.
One thing: I had to anchor seal quickly after cutting. I had been cutting blanks intending to seal them all at once, but before I noticed, some blanks started cracking on the end grain while I was still cutting up the chunk. I ended up cutting just a few then sealing which worked better.
JKJ in East TN
Re: Holly Question
Re: Holly Question
Jim King
>We have a couple of white woods and suscepatable woods to mold here in the Amazon and we are in fungas heaven with 90% humidity and 90 degree temps everyday. As I have said before use swimming pool chlorine one pound to 5 gallons of water and throw it in for an hour or a day, the more the better. And after it is dried on DRY stickers in a day or so do it again.
I will attach a photo of one corner of our shop showing several blanks treated in this way and no mold on any species.. The whiteness you see on some pieces is the chlorine dried on the surface, it lowers the brightness but only on the surfsce.
Re: Holly Question
Re: Holly Question
Barbara Gill, Remlik VA
>I had some very large holly blanks early last spring; most of which I sold. I turned a very large bowl (18")and soaked it in denatured alcohol with good results. I also soaked some smaller bowls 10" with equally good results. Just for your information I soaked rounded walnut blanks for rolling pins it should work for holly as well. It took a little longer for the walnut blanks to dry but if I remember correctly, they quit loosing weight after two months. They are about 2 1/2" in diameter and about 22" long. I think I left them soaking for about two weeks because I went out of town. If you are interested in a more exact report, let me know and I will check my information at the shop.
Re: Holly Question
what little I know
Tom Sontag - St. Louis
>I have some experience with drying white woods. It is a delicate balance between too fast and not fast enough. Air flow is the key to drying the surface of the wood, even before anchorsealing.
Having ruined a few pieces, I may try Jim's chlorine idea next time.
Re: Holly Question
Re: Holly Question
Gary Evans Tallassee, TN
>William,
If you don't have much time to deal with the wood at the moment, coat the ends with a fungicide as Jim suggests, dry quickly and then coat with Anchorseal. Leave the pieces as long as possible with the bark on as the stain actually moves fairly slowly through the wood. I've got some that has been stacked all summer, but is still nice and white when cut. Be aware that you'll need to repeat the process as you cut it up, because the surfaces will get a new inoculation of fungal spores as they are exposed.
Gary
Re: Holly Question
Re: Holly Question
Jim King
>We use shrink wrap for protection against drying to fast after the initial surface drying but we have tried saran wrap and the simple hardware store stretch wrap also and it slows the drying after the chlorine treatment as well as anchor seal and does not make a mess of the blanks.
Re: Holly Question
Re: Holly Question
>Thanks for the help and advise. Last night, I sealed the ends with Anchorseal as a stop-gap measure. The ends were still clean, and hadn't been in the dirt, so I'm hoping I didn't get any significant fungal inoculation. Today, I'll have to find some pool chlorine and a couple more buckets, so I'm ready to drop them in as I cut them up. I think this will take a while, as I don't have nearly as much room to work as Jim does. And, I'll get out the Poolon and the PPE and split them through the pith, at least.
Curiously, even though the tree, an American Holly, Ilex opaca, was standing very straight, the pith is way off center. I guess that must be typical of holly, as I see lots of straight big ones, but all the little ones are about a crooked as a snake. Like most hollies, this one had spent most of its life shaped like a Christmas tree, so there were branches almost all the way to the ground.
I couldn't imagine trying to work under Amazonian conditions. It does me in, trying to work an hour or two outside at 96° and only 50% humidity, like it was here yesterday. Next month, it will be much better here, but I know Jim and his people have to put up with it all year long.
Re: Holly Question
Porn
Stuart Johnson
>Jim,
I'm not certain but I think this is border line porn :>)
Re: Holly Question
Peter Charles Fagg (UK)
Re: Holly Question
>Unsure as to relevance, but UK Holly needs to be stacked in the vertical rather than lying down. If it is laid down, even after sealing, it tends to lose the lovely pure White very rapidly.
Stagnation of the sap possibly?
Regards Peter.
Re: Holly Question
Re: Holly Question
Jim King
>Peter:
What you say applies to many species and colors of wood here in the Amazon also. The best example is balsa wood, if stood upright for a couple of weeks -no stain, if dried laying down-horrible mess.
