little black bugs
little black bugs
little black bugs
kenny in Indep mo
>Hello, Need a little help. I opened a box of wood which was won on ebay. The wood was inside a bag. As I began to remove the last block of wood I saw a few very small black bugs in the bottom of the bag. I took the wood out and placed it on a table, about 30 minutes later I found a couple of small black bugs on the table. I then noticed small small round holes on the side of the block. I put the block back into the bag, tied it up and took it outside. Should I be worried about these bugs getting into my other wood in the shop? What would I use to kill them? As always, thanks for your time and help.
Re: little black bugs
Ed in No.VA
>Give it a shot in the microwave that should cook the wee devils. welcome to the world of powder post beetles.The do like the starches found in wood and will attack dry wood.
tdaniel
>a guy in our club says a jarlid of gasoline slipped into the plastic bag with the wood and sat out in the sun will kill about anything in it. This guy is very knowledgeable so give it a try and let us know.
TD
Robert Henderson
>I hope you reflected this problem in your feedback.
kenny in Indep MO
>Thanks for the help, blank is it bag, small amount of gas, and setting out in the 97 degree heat today. Posted ebay response before I found the bugs but have sent an email to the seller. Once again thanks, will check for bugs on Thur.
