Re: Jet Mini Lathe Stand size
Ed Moore
>Brian,
The top of the stand is two plates that are each 4 x 7 1/2". The distance between outside edges is 25". The bolt holes on the lathe are 6 3/8" F-B, and 23 3/8" S-S.
The 2 x 2" posts are 22" C-C, and the splayed bottoms will fit in a rectangle that is 24 1/4 x 33 1/2".
I chose to put a piece of 3/4" ash between the lathe and stand. It is 10 1/2 x 28". The excess width is in the back and I put a Moffatt lamp on a pivot arm with a radius swing of 14 1/2". I secure the lathe to the top and stand with bolts and wingnuts for easy disassembly.
Somebody forgot to measure the height when he went up to the shop to get the measurements. Anyway, the adjustment on the legs is pretty good.
