black locust salad bowl?
DWFII
>I've got a black locust bowl going and I'm wondering if the wood itself is a problem for food--salads, etc.?
I finished the inside of the bowl with pure tung (cut to about 25%) waited several days and sanded that down. Then a coat of shellac sanding sealer, dried overnight and sanded to 4000 abralon. Then I applied pure beeswax and burnished it in.
I figure/hope the finish is is food safe but wonder about the wood itself.
Any thoughts would be appreciated.
BTW...thanks to everyone who responded to my question about square scraper angles...I'm not the greatest at follow-ups but have no doubt I appreciate it and thank you. This forum and its members/contributers have made **the** difference in my turning.
DW
In the High Desert of Central Oregon
Re: black locust salad bowl?
Ben Aragon
>DW,
Check out these web sites.
Ben
http://www2.fpl.fs.fed.us/TechSheets/HardwoodNA/htmlDocs/robiniapseudo.html
http://www.fpl.fs.fed.us/documnts/usda/amwood/244black.pdf
FROM USDA Forest Service:
Toxicity: Wood as a material is not considered toxic or carcinogenic by the Environmental
Protection Agency (EPA), but sawdust is. However, almost all woods, including United
States native white pine and paper birch, have constituents that are allergenic or toxic to
someone. Most people, though, are unaffected by most woods. Dust generated in
woodworking may irritate skin and mucous membranes and even cause nosebleeds and respiratory
disorders. Timbers that are particularly toxic are noted when information is available.
If no information on toxicity is available, this does not mean that the wood or wood byproducts
are not toxic. If working with the wood is reputed to cause skin or mucous membrane
irritations, this is noted.
http://www.fpl.fs.fed.us/documnts/fplgtr/fplgtr83.pdf
Partial Hijack
>Your post includes the sentence:
"However, almost all woods, including United States native white pine and paper birch, have constituents that are allergenic or toxic to
someone."
I posted a question here a few weeks ago about turning walnut and birch. I had some type of allergic reaction. I had turned both in the same session. Most everyone thought it was most likely the walnut, but I have been working with walnut long before and now after the Birch. Where is there more information on the birch. Your post has turned my suspicion back to the birch. Does that sentence mean birch is more allergenic than other woods or should I read it to mean even the harmless old birch might have some such properties?
Re: Partial Hijack
Ben Aragon
>The latter, "even the harmless old birch might have some such properties".
Re: Partial Hijack
>>...walnut and birch. I had some type of allergic reaction...
Barry,
I can't remember if I mentioned this before, but if you want to find out if you are sensitive to a particular type of wood there is a simple self test you can try. Put a little sawdust of each under a bandaid or piece of tape on your forearm and leave them for a day or so. The small area of skin irritation might be a reasonable tradeoff for discovering which type of wood to protect against.
JKJ in East TN
