We value your privacy.
>Menzerna polish was recommended to me for a high gloss finish on woodturnings. Does anyone know how to use this stuff? Homestead Finishing recommended the #1 Pre-polish , #2 fine polish (very soft consistancy abrasives) & #3 final polish (a white cream) for wood. I applied it on a slow moving spalted maple bowl buffed at 1900 rpm with mixed results. Streaks (1/4 wide) gleamed like a piano top while other areas were dead dull.
>Without knowing a lot about what you are doing, I will try to make a few assumptions from your message.
I gather that you are polishing bare wood?? If you are, therein lies a problem. ALL areas of the wood being polished must be the same hardness and density in order to have a uniform polished surface. You mentioned "spalted" and that would make me believe that there are some differences in the hardness of the wood. Remember that spalting is the 1st stage of decay, and there will be places that are getting close to "rot". If all of the surface is not the same, the harder places will take a polish, and the softer ones will not.
This is not a problem with furniture surfaces because spalted wood isn't normally used for table tops.
The best way to solve the wood problem is to saturate it with an oil finish. Watco Danish Oil will do it, but an oil finish with polyurethane resins would be even better. Let it dry for several days to a week, and then use the polishing compounds or buffing wheels. The oil and resins fill and harden up the softer parts of the wood and leave a more uniform surface for polishing.
If you did use a finish on the wood before polishing with the compounds, I would suspect that the finish wasn't dry. An oil needs a week, lacquer between 1 and 2 weeks, and a shellac at least 2 weeks before the surface is hard enough for polishing.
>In the humidity of the summer on the east coast you may have to wait much longer before polishing an oil finish. Another problem may be that you have gone through the finish in areas. When I put an oil finish on I saturate the wood all the way through by starting the oil early when I start to sand, not after sanding to 2000 grit. Sanding to a high grit before starting the oil will assure of a very thin finish that can easily be buffed through.
>Hi Russ. After viewing your tapes I have been sealing spalted wood with shellac or Deft after sanding to 600 grit and before applying a Danish oil mix in hopes of reducing blotching. Am I doing this wrong and hurting penetration? Is there a better way to do both?
>I have not had any bowls drying long enough to buff and tell. I will post when I have buffed results. So far it has stopped any blotching if there was to be some and the finish seems to be less colored by the oil mix than before.
