Jet mini
Jet mini
Jet mini
Bud Gabaree
>I know this has been asked before, but who has the Jet mini at the best price and what is delivery time like? I'm interested in a mini for demo purposes, but is there a different or better small (transportable) lathe that is worth considering?
Thanks for the help in advance,
Bud
Re: Jet mini
Re: Jet mini
>You might look at the Carbo-tec. I believe Pen state Industries has one. I like the Jet better but it is quite a bit heavier than the Carbo-tec so if size and weight is important then take a look at that machine. It is a quality piece of cast iron. There are copies of this lathe on Harbour Freight. Don't buy one they are junk. The Carbo-tec has a little less swing and uses #1 morse taper accessories. The thread is 3/4 x 16 which is a common nut size so it's easy to make your own faceplates. I'll have to measure mine but I believe it is an 8" swing instead of 10. I really like it for Demo's. It's extremely portable and very quiet and solid.
Re: Jet mini
Re: Jet mini
Bud Gabaree
>Thanks John, I'll take a look at the Carbo-Tec.
Bud
Re: Jet mini
Carbatec
Phil Joines Krum, Tx
>I have the original black one. It's a good little lathe, especially with the VS treadmill motors that were available a while ago. The only trouble I had was losening of the spindle nut behind the hand wheel after turning some out of balance bowl blanks that where at the full swing capacity. Wasn't any problem to adjust.
