Fluting and drilling jig *LINK*
Fred in NC
>For quite some time I have wanted to add a fluting/drilling table to my Jet Mini. Problem is, being a small lathe, the banjo is simply too high for anything other than the usual tool rest. Pictures of Bill Johnston's jig can be seen at the link below. So I started looking around for a "low banjo."
Necessity being the uncle of tinkering, I did some experimenting. Rigidity was the main requirement, and I also wanted it fully adjustable. After some wasted plywood and MDF, I came up with the parts in the pic. They are 1/2 x 2" steel. One is the banjo itself, and the other a plate to hold the table.
http://www.kestrelcreek.com/toc.htm?id=22&cat=tech
Re: Fluting and drilling jig *LINK*
Fluting and drilling jig in place
Fred in NC
>In the pic below, the banjo is in place on my Jet Mini. It is being held by a bolt and a square nut that was made to fit my lathe.
The upright or post is 5/8" allthread. The nut below the top plate acts as a locknut, and also adds rigidity. Two nuts hold the post to the banjo, and make the height fully adjustable. This thing is rigid!
My indexing plate setup can be seen at the left. The plate is aluminum, and 24 holes were precision drilled with a machinist's mill and rotary table at a friend's shop. The indexing pin is tapered so there is no slop.
A table in place
Fred in NC
>In this pic you can see a table I made from some scrap MDF. I used a piece of 1/8" x 1" steel to make a ledge at the rear of the table. This is used to guide the router sideways. Please refer to Bill Johnston's article for more details. The banjo and table can take pieces up to about 6" in diameter.
Dremel holder in the makings
Fred in NC
>The main parts are done. The Dremel is held by the nose nut, and a pad to hold the rear part, making it more rigid, will be added. The bottom plate is PVC.
