Tigre Caspi Log Slices
Jonathan Spool
>Does anyone have experience turning and curing pieces from a Tigre Caspi log slice? They are offered at Exotic Wood World, and look great, but are quite green. I have not had the best experience in the past with turnings such as a platter, that included the pith. If I can find a 22" diameter container, perhaps an alcohol soak would do the trick, but that too seems to be species dependant.
So, if you've turned this wood, I'd love to hear of your experience.
Jonathan
Re: Tigre Caspi Log Slices
Eduardo Sarmiento Hall-Lima Peru
>Well I have no problem with the wood just turned to an inch thick and let dry for a week then return if you have or want to boil then just cut to size and follow the tips provided by jim king
