A55 Smoothing Plane
A question about CA glue and dyes
Russ Fairfield
>Can someone please provide me with some guidance and 1st hand knowledge, or an information source, for how to dye a CA glue??
I have read messages on this and other forums that profess to have 1st hand experience with dying CA glue. However, I have not been able to add dye to the CA, mix, and use WITHOUT setting off the curing reaction, or reducing the shelf life of the dyed glue to almost Zero.
Re: A question about CA glue and dyes
>I haven't used dye, but have you tried putting the CA in the freezer to slow the reaction? This has worked for me to extend the working time when working with sawdust and woods that tend to act as accelerators.
I got this tip from a pen turner who suggested cooling drilled pen blanks of certain woods in the freezer before applying cold glue.
JKJ in East TN
>Russ I've tried to color just about everything but CA glue. I'll be interested in the results. I wonder what would happen if you mixed a little analine dye with acetone then mixed this with the CA. The acetone may retard the drying time to the point that it won't work but I certainly don't think it will make it harden early. I'll try that tonight and see what happens. Get back with you tomorrow. John
RonZ
>While not impossible, almost any dye well set off the curing reaction. This is why most companies only sell balck, Starbond has an amber color. For the record, the black CA dries up much faster in the bottle than the regular. The amber is pretty stable. If I wish to dye a glue, I'll either use epoxy or plan for the CA to be cured rapidly and apply aaccordingly.
