Casters
Casters
Casters
Sean Troy
>Hey all, I want to put swivel casters on my 4224 Powermatic that also are locking casters. 4-5" size. Right now I have the lathe on (bolted) to 4x6's for the extra hight. I woulden't mind some more hight. Should I go with the 4 hole bolt on type, which I can bolt to the bottom of the 4x6, or the kind that have a through bolt that would go through the hole on the bottom of the leg? I can't find the through bolt type. The lathe weighs 1,000 lbs. Any help would be appreciated. Thanks, Sean
Re: Casters
Re: Casters
Chris In W. MI
>Her's some: http://www.hartvilletool.com/search.php
If you put Woodnet 15% in the comment slot when you order you will get a 15% discount.
Re: Casters
Re: Casters *LINK*
>I'd consider one thing: would adding casters take away from the stability and increase vibration when turning out-of-balance blanks? Smaller steel casters might be better than those with rubber tires. If you have a local Northern Tool you could browse their caster bins.
One possible alternative if you have the floor, space and resources - our local Woodcraft has a heavy lathe mounted on a low wood platform/frame. They slide a hand-operated fork lift under the frame to move the lathe. Seems like this would give you both the height and stability. One I see on the Northern Tool web site below costs about the same as a good chuck for the lathe. This would also be a great thing to have around the shop for other tasks.
JKJ in East TN
Industrial folding pallet truck
Re: Casters
Re: Casters *LINK*
Rick Allen
>Hi Sean
Thes guys have a LOT of different casters in a LOT of different sizes and rateings. I would sugest that you get the 1000 lb casters as those will move easly and mount securely. The brakes for casters are sold seperate so you can selsct the caster and break combo that you want.
I have bought casters from them and I was pleased with the product and service.
BTW I wouldn't put casters on a lathe.
Good Luck
Richard
Darnell Rose casters
Re: Casters
Leveling Casters *LINK*
Phil Joines Krum, Tx
>I haven't used these but they look interesting. The leveling foot would raise the wheel off the ground wich should removing the instability.
I'd like to hear from anyone who has used them.
http://www.mjvail.com/carrymaster.htm
Re: Casters
Re: Casters
woodspinner/ Bill Hale
>Sean
Consider mounting the castors outboard on the head end. When you mount set them so they only slightly clear the floor. On the tail end use adjustable castors. By raising the adjustable full height you should be engaging the fixed. The adjustables need to be rotating to allow the ability to turn the lathe. You can buy a steel wheel with a plastic coating as used on hand type pallet jacks. Check Harbor Freight.
This allows to be set firmly on the floor when the castors are raised.
If this is confusing drop me a note with your fax no and I will send a drawing.
Bill
Re: Casters
Re: Casters
Sean Troy
>Thanks all for the help, Sean
Re: Casters
Re: Casters
Gary Ljostad
>Here is a pic of the castors and leveling device that I used on my 3520. Each castor will hold 600#. They are from vending machines. A welder friend made the brackets from 3" angle iron and 5/8" threaded rod.
Re: Casters
Re: Casters
Gary Ljostad
>You can find these castors at the following link.
http://cgi.ebay.com/Heavy-Duty-Stem-Caster-Set-Casters_W0QQitemZ7534499693QQcategoryZ56997QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem
