reversing the spindle on Jet 1442
ben d
>Reading the post on installation of a spindle reversing switch for the jet mini W/ DC motor.
Has anyone or can it be done on a Jet 1442 110/220 AC ?? If so installation instructions please.
Re: reversing the spindle on Jet 1442
Scott Crumpton
>In theory it should be reversible. But is it practical to do it? I have a 1442 and was asking myself this question just last week. I guess I’ll go check it out if no one jumps in here with a definitive answer first.
Most 2 phase AC induction motors can be reversed by reversing the connections of the start-up winding. But it all depends on having access to those connections. If they're available it’s easy. Otherwise a disassembly of the motor would be required to bring them out. The 1442’s motor does not have a terminal block that brings out the start-up winding. However, it does have two start-up caps, so there’s a chance that both ends of the start winding are available (1 at each cap) outside of the motor housing.
---Scott.
Oops - That should read single phase
Scott Crumpton
>Oops, that should read "single phase". Not "2 phase".
BTW - You reverse 3 phase motors by swapping any two of the three lines.
ben d
>Scott''
I will be digging around also and if you come up with anything let me know or make a post.
Ken Grunke from SW WI
>As Scott said, you just reverse the connections on the start winding or the start capacitor and you can use the same kind of switch that I had in my diagram or in Mack DeBose's PDF file.
But with any AC motor of this type (single phase) the motor has to be stopped before you turn the power back on in the opposite direction. You can flip the switch in reverse while the motor is spinning, and it will just continue in the same direction.
One way to improve this situation is DC current injection braking, which works with most any AC induction motor by applying a low voltage, high current to the motor windings to stop the motor in 1 to 10 seconds depending on how much current is available. If you want to look into that, do a Google on DC injection braking.
You can have the braking action done in the switch's middle position, then flip manually to reverse positon--or use an electronic timing circuit to hold the braking current for a specified time and automatically switch into reverse. Not an afternoon project unless you're an electronics buff, but not rocket science either and the info is freely available from many sources.
