reversing the Jet Mini
Phil Powell
>I have a Electronic speed controled Jet Mini and I think it's a great small lathe! But, it does
have one or two short comings. The one I want most is reverse. Does anyone know if
reverse is possible and if so how?
Re: reversing the Jet Mini
john Lucas
>It will reverse. You would have to swap the leads on the motor. I did this on another lathe using a double throw switch. You would need to mount it somewhere on the lathe in a box and then run new wires from the speed controller. My scanner is down so hopefully someone will have a drawing they can send you on how to wire the switch. If not e-mail me with your snail mail address and I'll make a sketch.
Mike in Fort Walton Beach, FL
>I was wondering that myself. I'm getting ready to get a VS Jet Mini and was thinking about that last night. I saw a video by an older guy (can't remember the name) who swore by sanding in reverse. I tried on a friend's lathe and it really did make a big difference. If anyone gets a copy of the drawing and wants to send it to me too, I'd appreciate it. My e-mail is mandriacco1@yahoo.com. Or, if someone wants to give me a good step by step, I can do up a quick schematic or block diagram in Visio and post it as a pic for all to see. Thanks.
Mike
Re: reversing the Jet Mini--diagram
Ken Grunke from SW WI
>here's something I whipped up in my drawing program--
The switch is represented by the dotted box on the left, it has 6 poles. The middle poles are common, and go to the motor.
The black arrows are the movable contact arms, always connected to the common poles.
The power leads from the control box are connected to two outer poles of the switch, then continue on to the other two outer poles but reversed.
The top view is forward, bottom is reverse.
Hopefully this shows clear enough that only one pair of outside poles are connected at one time, and that this hookup allows you to put the switch anywhere between the control box and motor where convenient.
Phil Powell
>Thanks guys! Guess I'll have to gut up get out the wire cutters
and have it. I don't think I can mess it up too much.
Re: reversing the Jet Mini *LINK*
Brian Hahn in SW Wisconsin
>There's a two-page article written by Mack DeBose on the Gulf Coast Woodturners site.
Reversing Switch for Jet Variable Speed Mini Lathe
Phil Powell
>Brian and everyone that wrote answers thanks! That's the best thing about this
site, people helping people.........lots of sharing!
Devon Palmer
>It makes a guy wonder why Jet didn't include it as a feature given the ease of it.... What would be the worst thing that could happen to the motor if it wasn't particularly suited for reversing? Wierd brush wear or something? I would assume neither lathe nor motor bearings would care about the direction of rotation.
BRUSHES ???
Fred in NC
>My Jet Mini did not come with VS. I did my own conversion. So I am not familiar with the motor in the VS. From the above discussion I gathered the motor is the PERMANENT MAGNET type. These turn in different directions according to the DC polarity, so the reversing switch will work.
HOWEVER, motors with brushes are UNIVERSAL motors. Reversing the polarity to the motor will not reverse the direction. A reversing circuit would have to be wired to the inside of the motor, between the brushes and armature.
