We value your privacy.
>I would like to try some microwave drying of green wood. I will be turning 6-8" bowls. How thick for first turning, how long for heating and drying etc. and returning to lathe for finishing. Many thanks.
I haven't dried any bowls for rough turning but have dried plenty that I've turned to final thickness. I turn mine down to 1/4 or 3/8 depending on how big the bowl is and how I want it to look. Then I microwave no more than 15 seconds in the beginning and let it completely cool before doing that again. I usually do this while I'm working so sometimes there will be 15 minutes between cycles and sometimes an hour or more. As it dries I'll increase the time. I watch how the moisture comes out of the bowl. The first 4 or 5 times you'll see quite a bit. When I don't get moist spots as large I increase the time. It usually take me a day off and on all day to dry one completely.
If I was doing a rough turned bowl Iwould turn it to a thickness of 10 percent of the total size. About 1 inch for a 12 inch bowl. I turn the bottom thinnner because it doesn't warp as much and that way the tenon on the bottom is closer to the thickness of the rest of the bowl. This is where mine crack most often.
>If you cover up some of the vent holes on the inside of the microwave it will give you more of an immitation of a true dry kiln with a higher moisture content that will even out the drying process and prevent too fast a drying that would otherwise have a tendency to make uneven drying and lead to cracking. Include punctuation marks at will !
I've always removed my wood from the microwave after each heating cycle. Are you saying you leave it in? When drying flat end grain pieces for plugs boxes I heat the wood and then put it in a plastic bag to cool down. Noot sure that's essential but it has reduced cracking.
I put mine in a plastic bag also but with a paper towel around it to help absorb moisture as it cools down. When the paper towel ceases to soak up any or very little moisture, it is done.
>I dried some wood (not bowl blanks) just a week ago.
I weighed the blanks (I used a triple-beam balance scale), then microwaved for 30 seconds. I removed them from the oven and let them cool completely before repeating. I tried to let them cool (and let off "steam") for at least 30 minutes but preferably an hour at each step. I recorded the weight at each step and repeated until the weight change was very small. (Best to plot the curve.)
>John: Just think of how a commercial dry kiln feels when you peek inside. It is hot and steaming . By slowly lowering the humidity in the kiln, the wood drys all the way through, slowly. I confess that at times I get immpatient and put a little too much heat to the piece and then have to repent and cut down the heat range, but by leaving the piece in the oven with the higher humidity I am approximating what you accomplish with the plastic bag without the trouble of monkying around by wrapping and un wrapping the work piece. It takes a dedicated microwave and a little bit of experimenting to know just how much of the venting to cover up.
