Black Oak Burl Bowl Large
Les Robison
>Here is the mother bowl of the pair. I used a McNaughton to core out a small bowl. The original limb burl yielded two large bowls and weighed over 100 lbs. It was bone dry. It is 10" wide and 7" high with a 1/16" raised foot to create a shadow line. The walls are about 3/4" thick, which I thought showed the proper character for a rough and tumble burl like this. Finished with Watco Danish Oil. Comments are welcomed.
Re: Black Oak Burl Bowl Large
Dave Fuqua
>I like the manzanita and the black oak pair. I'm a big fan of thicker walled bowls but then again I have clumsy dogs and cats that like to knock stuff over.
I just started turning and I've wanted to order a manzanita root burl to turn. How does it turn? It looks extremely cool in an exotic, almost primative way.
Dave
Les Robison
>Manzanita roots are VERY IRREGULAR in shape and the wood is quite hard. With that in mind, the challange is to get the mass turned into a somewhat round shape. There is a lot of tool bounce as you go through that process. It is much llke taking a square bowl blank and trying to make it round. Also the root ball has dirt, rocks, and other foreign matter in them which dulls tools and makes a mess. With all that said, it is fun and very rewarding when you get done with one. You owe it to yourself to try.
>Nice set of bowls. Coloration is "rich". That is some nice grain.
Steven Antonucci
Like this one a lot
steve antonucci
>Now that I've gotten "thinner means better" out of my head, I have started to appreciate heavier forms. I like this shape, and you are correct it suits the wood.
If you have a suitable off cut, you might consider turning a pestle. The first thing I thought when I saw this was mortar and pestle.
Steve
