Lathe mounted 12in sanding disk
Bob R
>A while back there was some info on making a 12 inch spindle mounted sanding disk and a table mounted on the lathe bed for sanding segmented bowl parts. I have looked but can't find the thread. Please help.
Thanks
Bob R
WestMac Turning
Re: Lathe mounted 12in sanding disk
Re: Lathe mounted 12in sanding disk *LINK*
Jeff Gerardot, Indianapolis IN
>I found it in the turning archives, see link below. One of the responses discusses the sanding disk idea.
http://www.woodcentral.com/cgi-bin/archives_turning.pl?read=39205
Bob R
>THANKS
That gives me a lot of answers to others questions also.
Bob R
Brad Vietje
Brad Vietje
>First, a disclaimer: I don't make segmented turnings, and all my hollow forms are one piece, or single pieces with an applied spout.
That said, I thought I'd throw out that ShopSmith has re-introduced a neat twist on the 12" disk sander -- a 12" disk with a 4 degree conical shape, and specially-shaped adhesive sanding disks that fit it. The idea is that you tilt the work table to 4* to be perpendicular to the conic shape, so when you then pass a piece of wood across the sanding disk, it only contacts along a narrow strip, instead of sanding the entire flat surface at once.
Anyway, I thought this might have some interesting applications to segmented turning, so I thought you might want to look into it. The Shopsmith web site is www.shopsmith.com, but nowadays you have to be a registered user to see all that's there -- you could always request a catalog for more info.
Safe Spinning,
Brad Vietje
Thetford, VT
Re: Does this help
Russ Fairfield
>I prefer the fixed table because it is always lined up with the disc. I have another made for 30-degrees and one for 45-degrees.
An advantage of the sanding disc on the lathe is the variable speed. I like about 500 RPM. Commercial discs running at 1750 RPM can burn the wood and remove it too fast to be useful for fitting segments.
Re: Does this help
Bob R
>Big Thanks to both Brad and Russ.
All help is very welcome.
Again THANKS
Bob R
